Axxess AX-ALOC10 2-Ch 30W Speaker to Line Level Output Converter
Brand:|Model: AX-ALOC10|Part # 266-004
Axxess' 2-channel AX-ALOC10 connects to a mobile audio head unit's speaker-level output and converts it to line-level RCA output, for use with line-level only mobile audio electronics like equalizers, active crossovers, and amplifiers. Great for adding powered subwoofers to OEM stereos! 15W/channel.
List Price$8.99
You Save14%
$7.73
Buy 4+$7.08
Part # 266-004
  • 15W x 2 power handling
  • Converts speaker output to line-level output
  • Small size and easy to install
  • Fixed 6:1 power step-down ratio
The adjustable Axxess AX-ALOC10 two-channel speaker-level to line-level converter (also called a high-to-low adapter) allows for the installation of line-level mobile audio electronics, such as amplifiers and active crossovers, into systems without a line-level signal by using the head unit's speaker output. Great for adding powered subwoofers to OEM systems. Handles up to 15 watts per channel and has a fixed, 6:1 power step-down ratio.
  • BrandAxxess
  • ModelAX-ALOC10
  • Part Number266-004
  • UPC086429213559
  • Product CategoryLine Output Converters & Controls
    (1 Reviews)
  • Weight0.15 lbs.
View similar products to the Axxess AX-ALOC10 2-Ch 30W Speaker to Line Level Output Converter
in the Line Output Converters & Controls product category.
Axxess AX-ALOC10 2-Ch 30W Speaker to Line Level Output Converter is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from A Good Buy !This convertor hooked up easily. I've got an adjustment on my amp so I didn't need one on my convertor. The sound comes through perfectly with only the smallest amount of noise, good S/N ratio. I'm using it with a factory radio feeding my sub. Very good.
Date published: 2012-10-30
  • 2016-02-06T06:45CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_266-004, PRD, sort_mostRecent
I have a 1998 Lexus LS 400 with a Nacamichi head unit and the factory Pioneer amp I bought a Dayton Audio sub and a Aura transducer. The sub only had 2 wires can I connect the single channel to both channels of High/Low converter and then to the amp
Asked by: RJones
Date published: 2015-11-12
Getting hum, need ground loop isolator?
I got this to connect the speaker output from my arcade cab amp to the input of another amp (for more power). The amp and speakers by themselves seem fine from testing with other sources, but from the cab output through this speaker-line converter I'm getting a lot of hum/buzz with the ground reference cable connected, while without it the level is really low and tinny, along with a hum still. Would a ground loop isolator like the ones linked fix my issueDouble checked the wiring and everything appears to be connected properly...but I'm not entirely sure on the ground cable. I connected that to what appears to be a ground point on the cab itself, while the amp itself doesn't seem to have a connection for a ground.
Asked by: japtor
Yes you just need to lift the ground. Either device will work, simply ground it to a ground on the cab itself.
Date published: 2013-07-10
  • 2016-02-06T08:21CST
  • loc_en_US, sid_266-004, PRD, sort_recentQuestionsFirst
