Avel Y236850 625VA 25V+25V Toroidal Transformer
Brand:|Model: Y236850|Part # 122-675
Transformers are wound with heavy gauge copper and are wrapped with polyester tape. Meeting all major industry standards, these include double-insulated primary leads and a mounting kit with plate, pads, nut, and bolt.
List Price$138.99
You Save29%
$98.00
Part # 122-675
AVEL's Y23 series power transformers offer exceptional value and performance for use in any high-quality power supply. All Y23 transformers are wound with heavy gauge copper and are wrapped with polyester tape. Meeting all major industry standards, these include double-insulated primary leads and a mounting kit with plate, pads, nut, and bolt. Other features include: 3% secondary tolerance at full load, 6" stranded copper leads with PVC insulation, and UL506/ CSA 22.2 and CE certifications
Specifications: • Primaries: 115V + 115V • Frequency: 50/60 Hz • Load Capacity: 625 VA • Secondary Voltage: 25V + 25V • Dimensions: 5.4" D x 2.6" H • Weight: 10.8 lbs.
  • BrandAvel Lindberg
  • ModelY236850
  • Part Number122-675
  • UPC844632051142
  • Product CategoryToroidal Power Transformers
  • Weight11.5 lbs.
View similar products to the Avel Y236850 625VA 25V+25V Toroidal Transformer
in the Toroidal Power Transformers product category.
How big a transformer do I need?
I am building a sound system with four 100Watt amps. I need a power transformer and I'm looking at your 625VA 25 + 25 toroid trans. But I wounder if that would be over kill? Would the 330VA 25 + 25 trans work just as well?
Asked by: Leastless
You need to figure out how many amps (current) your 100 watt amps will pull under load with the 25 volts input, this transformer will put out 12.5 amps per leg. Class AB amps will draw about 2 to 3 times the power as they output, so if you have four 100 watt AB amps they may need an 800-1200VA transformer.Class D on the other hand will be much more efficient close to 90% so something like the 500VA will do.
Answered by: mtg90
Date published: 2012-03-26
  • 2016-02-10T07:52CST
  • loc_en_US, sid_122-675, PRD, sort_recentQuestionsFirst
