Avel Y236103 30VA 15V+15V Toroidal Transformer
Brand:|Model: Y236103|Part # 122-605
Transformers are wound with heavy gauge copper and are wrapped with polyester tape. Meeting all major industry standards, these include double-insulated primary leads and a mounting kit with plate, pads, nut, and bolt.
List Price$38.99
You Save31%
$27.00
Part # 122-605
AVEL's Y23 series power transformers offer exceptional value and performance for use in any high-quality power supply. All Y23 transformers are wound with heavy gauge copper and are wrapped with polyester tape. Meeting all major industry standards, these include double-insulated primary leads and a mounting kit with plate, pads, nut, and bolt. Other features include: 3% secondary tolerance at full load, 6" stranded copper leads with PVC insulation, and UL506/ CSA 22.2 and CE certifications
Specifications: • Primaries: 115V + 115V • Frequency: 50/60 Hz • Load Capacity: 30 VA • Secondary Voltage: 15V + 15V • Dimensions: 2.6" D x 1.1" H  • Weight: 0.88 lbs.
  • BrandAvel Lindberg
  • ModelY236103
  • Part Number122-605
  • UPC844632051005
  • Product CategoryToroidal Power Transformers
    (3 Reviews)
  • Weight1.4 lbs.
View similar products to the Avel Y236103 30VA 15V+15V Toroidal Transformer
in the Toroidal Power Transformers product category.
Avel Y236103 30VA 15V+15V Toroidal Transformer is rated 4.6667 out of 5 by 3.
Rated 5 out of 5 by from near perfect preamp trannieused this for a preamp kit i built; supplied the voltage required; the size also was an exact fit for the case. happy user.
Date published: 2011-08-22
Rated 5 out of 5 by from would have been greatwell i think that this is very well made, it is very sturdy and seems like it would last a long time. however, when you hook it up wrong then things arent so smooth. even though this is only 15 volts it was able to blow up a 10,000uf nichicon 25V cap in my face...... it was kind of awesome. please remember to wire things right, and when sparks fly out from your project unplug, then check to see what's up. not stand there looking at it until it shots the aluminum cap upwards hard enough to dent the ceiling. that is all.
Date published: 2008-11-12
Rated 4 out of 5 by from Transformer meets all of its ratings.As expected this toroidal operates very quietly with no mechanical buzzing under full rated load. Also its VA curve follows the spec very well.
Date published: 2008-04-14
  • 2016-02-06T07:22CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_122-605, PRD, sort_mostRecent
I'm trying to figure out the type fuse I need for my project using this power trans former. It's drawing us 110 current and splitting off into 15v secondaries. The project calls for a slow blow fuse I believe.. Any help?
Asked by: Jeff hucik
Date published: 2015-04-14
can I use this product for a split 15v positive and 15v negitive, 0  ground for a preamp
Asked by: OMK3
It should work fine: keep in mind that when you connect the secondary to a bridge rectifier and the center tap to the center of a pair of filter capacitors, the raw DC voltage will be +/- 20-21 volts. You will need to use a 7815/7915 or LM317/LM337 pair of voltage regulators to obtain the +/- 15 volts your preamp circuits want.
Answered by: Rational35
Date published: 2015-04-04
I live in Singapore. My voltage supply is 220~240V. Your supply is 110V. in the primarily. Do you have that voltage rating in the primary of 220?.
Asked by: HK Long
These transformers have 2 115 volt primary windings. Wire them in series with your 220 volt and it will work fine.
Answered by: Soundmann
Date published: 2015-03-21
  • 2016-02-06T08:53CST
  • loc_en_US, sid_122-605, PRD, sort_recentQuestionsFirst
