Aura RPM4200 RPM Stage 2 Mobile Amplifier 4x50W
Brand:|Model: RPM4200|Part # 269-190
Aura's RPM Stage 2 RPM4200 amplifier delivers four 50 watt channels of power, and features all the user-configurable crossover and EQ options needed to make your system sound its best.
Part # 269-190
  • Bridgeable and 2 ohms stable
  • Class AB circuitry for solid, high fidelity sound quality
  • MOSFET high performance power supply design
  • Gold plated RCA jacks, power input, and speaker output
  • Protection circuitry against short, over current, thermal, and DC offset
  • All channel pairs have selectable crossover functions for high pass, low pass, or full range
  • Cool back-lit top Aura logo in "Aura blue"
AuraSound's RPM Stage 2 amps sound great and look great. Their designed and engineered in the USA features include a modular internal layout, comprehensive protection circuitry, and a highly efficient heat sink that makes external fans unnecessary.
Specifications: •Power output: 4 x 75 watts into 2 ohms, 4 x 50 watts into 4 ohms, 2 x 150 watts bridged mono into 4 ohms •Total harmonic distortion: 0.5% THD, 20 Hz to 20 kHz at rated output •Signal to noise ratio (S/N): > 85 dB •Input sensitivity: 150 mV~ 5 V (low level), 1.5 V to 25 V (high level) •Frequency response: 20-20,000 Hz •Dimensions: 9-1/8" W x 2-1/4" H x 14-1/4" L.
Additional features: •Variable remote bass level control 0 to +10 •Variable level controls •Variable 18 dB per octave low-pass crossovers (50-250 Hz) •Variable 18 dB per octave high-pass crossovers (50-250 Hz) •Switchable 10 dB bass boost at 55 Hz •Preamp outputs provide system design flexibility •High level inputs for OEM integration •Large 8 AWG compression terminals for system connection •Power/protect LED indicator.
  • Input TypeRCA Line Level,Speaker Level
  • RMS Power Output (Per Channel 4 Ohms)50 Watts
  • Special Features2 ohm Stable,Preamp Outputs,Bridgeable
  • Output Channels4
  • BrandFactory Buyouts
  • ModelRPM4200
  • Part Number269-190
  • UPC794002313304
  • Product CategoryCar Amplifiers
    (3 Reviews)
  • Weight12 lbs.
View similar products to the Aura RPM4200 RPM Stage 2 Mobile Amplifier 4x50W
in the Car Amplifiers product category.
