299-030_ALT_0
299-030_ALT_1
Aura NS6-255-8A 6" Paper Cone Neodymium Magnet Woofer
Brand:|Model: NS6-255-8A|Part # 299-030
Aura's NS6-255-8A 6" woofer uses its underhung NRT motor design to great effect. It produces very impressive amounts of deep bass, and does it with a minimum of distortion.
Part # 299-030
  • NRT neodymium radial magnet design
  • Smooth midrange and impressive bass output
  • Underhung voice coil provides exceptional excursion
  • Useful response to 5.5 kHz
  • Paper cone with foam half-roll surround
  • Sturdy stamped steel basket
  • Vented pole piece
The Aura NS6-255-8A is a compact, lightweight bass driver for music playback and home theater systems. Aura's NRT motor design arranges eight precisely arced neodymium magnets in a circle surrounding the vented pole piece, creating an exceptionally deep and strong magnetic gap. The deeply set, underhung voice coil keeps more wire in the gap during operation than conventional designs, delivering astonishing low-distortion bass capability far in excess of what the driver's nominal Xmax rating would suggest. Buyout, limited quantities.
  • Nominal Diameter6"
  • Power Handling (RMS)50 Watts
  • Power Handling (max)100 Watts
  • Impedance8 ohms
  • Frequency Response55 to 5,500 Hz
  • Sensitivity91 dB 1W/1m
  • Voice Coil Diameter1"
  • Resonant Frequency (Fs)55 Hz
  • DC Resistance (Re)6 ohms
  • Mechanical Q (Qms)10.5
  • Electromagnetic Q (Qes)0.58
  • Total Q (Qts)0.55
  • Compliance Equivalent Volume (Vas)0.58 ft.³
  • Mechanical Compliance of Suspension (Cms)0.9 mm/N
  • BL Product (BL)6.1 Tm
  • Diaphragm Mass Inc. Airload (Mms)9.3g
  • Maximum Linear Excursion (Xmax)3.9 mm
  • Surface Area of Cone (Sd)126 cm²
  • Cone MaterialPaper
  • Surround MaterialFoam
  • Magnet MaterialNeodymium
  • Overall Outside Diameter6.16"
  • Baffle Cutout Diameter5.35"
  • Depth3.24"
  • # Mounting Holes8
  • BrandAuraSound
  • ModelNS6-255-8A
  • Part Number299-030
  • UPC844632090561
  • Product CategoryProducts
    (40 Reviews)
  • Weight1.15 lbs.
View similar products to the Aura NS6-255-8A 6" Paper Cone Neodymium Magnet Woofer
in the Products product category.
Videos
