Aura Cougar NSW1-205-8A 1" Extended Range Speaker Driver
Brand:|Model: NSW1-205-8A|Part # 299-014
AuraSound designed the 1" extended range "Cougar" driver with bleeding edge loudspeaker technology for the highest quality, full range sound, in the smallest possible package. Great for modern applications such as speaker bars, desktop computer speakers, thin tower speakers, and line arrays.
Comparable Items In Stock:
Part # 299-014
  • NRT radial neodymium motor for extremely low distortion
  • Full range, 1" underhung driver with 4.5 mm of Xmax
  • Small frame size for reduced center-to-center distance and reduced comb filtering when used in arrays
  • Extreme ventilation for great power handling
  • Great for modern audio applications including sound bars and ultra-thin tower speakers
The AuraSound "Cougar" NSW1-205-8A 1" extended range driver is packed with next-gen speaker technology. An NRT™ neodymium radial magnet motor submerses the 20 mm, underhung voice coil in magnetic flux for supreme control, low distortion, high output (for its size), and wide frequency range without stray magnetic fields that could potentially damage sensitive electronics, while the extreme venting provided by a capless pole piece evacuates air that would otherwise be compressed (in a driver this size).
A titanium cone is mated to a foam surround to reduce cone breakup, for an extremely linear frequency response from 250 to 20,000 Hz. The low, 220 Hz free air resonance combines with 4.5 mm of Xmax (9 mm maximum peak-to-peak excursion) to allow for low crossover points, meaning you can pair the Cougar with nearly any woofer up to 5 feet away (2-1/2 ft. is the recommended maximum) seamlessly.
AuraSound built the NSW1-205-8A with a non-resonant, minimalistic, rear-mount frame for close center-to-center placement which is especially important in line arrays to minimize comb filtering. When used in series-parallel groups of four, the Cougar's output is increased from 78 dB 1W/1m to roughly 84 dB 1W/1m, with power handling increased to 20 watts RMS. Grouping eight together, and wiring for 4 ohms, yields roughly 90 dB of output at 1W/1m with power handling increased to 40 watts RMS.
Adding a series 80 microfarad capacitor creates a 250 Hz, 1st-order high pass and increases power handling. When wired in pairs or groups for a 4 ohm load, use a series 160 microfarad capacitor for the same effect. Factory buyout, supplies are limited to parts on-hand.
  • Nominal Diameter1"
  • Power Handling (RMS)5 Watts
  • Power Handling (max)20 Watts
  • Impedance8 ohms
  • Frequency Response220 to 20,000 Hz
  • Sensitivity78 dB 1W/1m
  • Voice Coil Diameter0.79"
  • Resonant Frequency (Fs)220 Hz
  • DC Resistance (Re)6.3 ohms
  • Voice Coil Inductance (Le)0.28 mH
  • Mechanical Q (Qms)2.1
  • Electromagnetic Q (Qes)1.1
  • Total Q (Qts)0.7
  • Compliance Equivalent Volume (Vas)0.01 ft.³
  • Maximum Linear Excursion (Xmax)4.5 mm
  • Surface Area of Cone (Sd)5.31 cm²
  • Cone MaterialTitanium
  • Surround MaterialFoam
  • Voice Coil Wire MaterialCCA
  • Voice Coil FormerAluminum
  • Basket / Frame MaterialPolymer
  • Magnet MaterialNeodymium
  • Overall Outside Diameter2.17", across flats 1.54"
  • Baffle Cutout DiameterRear mount 1.42"
  • Depth0.49"
  • Bolt Circle Diameter1.69"
  • # Mounting Holes4
  • BrandAuraSound
  • ModelNSW1-205-8A
  • Part Number299-014
  • UPC848864007076
  • Product CategoryMidrange / Midbass Drivers & Full-Range Speakers
    (2 Reviews)
  • Weight0.1500 lbs.
View similar products to the Aura Cougar NSW1-205-8A 1" Extended Range Speaker Driver
in the Midrange / Midbass Drivers & Full-Range Speakers product category.
