Audyn True Copper Cap 1.5uF 630V Copper Foil Capacitor
Brand:|Part # 027-159
Choose Audyn's 1.5 µF True Copper Cap, German-made capacitor for pure signal filtering as a high-pass capacitor for speakers or for use in replacing capacitors in the signal path of high-end audio gear.
List Price$64.99
You Save19%
$52.39
Buy 10+$47.15
Part # 027-159
  • Designed for the most transparent sound possible
  • Oxygen-free, non-inductive copper foil design with polypropylene dielectric
  • Seven 0.5 mm Tritec tinned wire leads for flexibility and a larger surface area for soldering
  • Precision made in Germany with 2% tolerance
  • High 630 VDC voltage rating
Audyn's True Copper Cap line of capacitors is German-made to an exacting 2% tolerance using ultra-pure OFC (oxygen free copper) foil electrodes and a polypropylene dielectric. This combination of capacitor materials provides a clean, neutral, "signal-in is signal-out" sound. No strange mixtures of various materials or, as the manufacturer says, "fairylike oils". The use of pure copper also reduces inductance for the greatest possible extension.
European users of the Audyn True Copper Cap capacitors regard them as spatially remarkable, great for imaging, and naturally balanced. Extract the best possible performance from your speakers' drivers, and hear everything on high resolution recordings. Audyn's True Copper Cap capacitors are also great for upgrading capacitors in the signal path of high-end audio components.
Specifications: • Value: 1.5 µF • Dimensions (diameter x length): 50 x 50 mm • Voltage rating: 630 VDC.
  • Capacitance1.5 µF
  • Voltage Rating600V
  • Tolerance2%
  • BrandAudyn
  • Part Number027-159
  • UPC848864015453
  • Product CategoryMetalized Polypropylene Crossover Capacitors
    (1 Reviews)
  • Weight0.4500 lbs.
View similar products to the Audyn True Copper Cap 1.5uF 630V Copper Foil Capacitor
in the Metalized Polypropylene Crossover Capacitors product category.
Audyn True Copper Cap 1.5uF 630V Copper Foil Capacitor is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Not only for speakers crossover! Coupling signal!!Great for coupling caps. Had this in a tube cd player as a coupling caps. beautiful sounding, midrange is to died for! Very musical, highs are musical and bass is ok. I would compare the Copper Audyn caps with the Mundolf supreme and silver. I would take this over the Md Supreme. This can compare to the Audionote Silver mylar, but the An silver shines on the highs and much cleaner on the bass. The Audyn is what $54 compare to the Audionote silver $400. Only really an even comparison. How does it compare to the Duelund copper Rs series? I would take the Rs series. Lower noise, even balance caps and much romantic caps. But if you like midrange then go with the Audyn, you will notice a big improvement on the midrange. Happy Listening!!
Date published: 2015-08-29
  • 2016-02-12T06:50CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_027-159, PRD, sort_mostRecent
