New Product
Audyn True Copper Cap 1.0uF 630V Copper Foil Capacitor
Brand:|
Choose Audyn's 1.0 µF True Copper Cap, German-made capacitor for pure signal filtering as a high-pass capacitor for speakers or for use in replacing capacitors in the signal path of high-end audio gear.
  • Designed for the most transparent sound possible
  • Oxygen-free, non-inductive copper foil design with polypropylene dielectric
  • Seven 0.5 mm Tritec tinned wire leads for flexibility and a larger surface area for soldering
  • Precision made in Germany with 2% tolerance
  • High 630 VDC voltage rating
027-157
Weight: 0.3000 lbs.
IN STOCK
List Price$59.99
You Save23%
$46.15
Buy 10-up$41.54
Part # 027-157
Audyn's True Copper Cap line of capacitors is German-made to an exacting 2% tolerance using ultra-pure OFC (oxygen free copper) foil electrodes and a polypropylene dielectric. This combination of capacitor materials provides a clean, neutral, "signal-in is signal-out" sound. No strange mixtures of various materials or, as the manufacturer says, "fairylike oils". The use of pure copper also reduces inductance for the greatest possible extension.
European users of the Audyn True Copper Cap capacitors regard them as spatially remarkable, great for imaging, and naturally balanced. Extract the best possible performance from your speakers' drivers, and hear everything on high resolution recordings. Audyn's True Copper Cap capacitors are also great for upgrading capacitors in the signal path of high-end audio components.
Specifications: • Value: 1.0 µF • Dimensions (diameter x length): 40 x 50 mm • Voltage rating: 630 VDC.
  • Capacitance1.0
  • Voltage Rating600V
  • Tolerance2%
  • BrandAudyn
  • Part Number027-157
  • UPC848864015439
  • Product CategoryCrossover Capacitors
  • Weight0.3000 lbs.
View similar products to the Audyn True Copper Cap 1.0uF 630V Copper Foil Capacitor
in the Crossover Capacitors product category.
Customer projects that include: Audyn True Copper Cap 1.0uF 630V Copper Foil Capacitor
