Audtek Electronics WHIREB IR Emitter Blaster
Brand:|Model: WHIREB|Part # 182-882
Audtek Electronics' WHIREB IR emitter blaster has the ability to flood multiple components within a rack with IR control commands, reducing the clutter caused by attaching an emitter to each device to be controlled.
Wired Home is now Audtek
List Price$19.99
You Save25%
$14.90
Buy 4+$14.25
Part # 182-882
  • Floods a component rack or cabinet with IR
  • Peel-and-stick design
  • 10 ft. control cable with 3.5 mm mono plug
  • Deep purple blaster body is inconspicuous—even in plain view
  • Wide bandwidth design—compatible with nearly all IR equipment on the market
Audtek Electronics' WHIREB IR emitter blaster has the ability to flood multiple components within a rack with IR control commands, reducing the clutter caused by attaching an emitter to each device to be controlled. At the same time, this reduces the number of emitter ports occupied on an IR hub, allowing for a single hub to be used over multiple zones. Each emitter blaster has been designed using a very deep purple plastic and easily disappears from view within a room; the peel-and-stick adhesive attaches to almost any surface for trouble-free, long lasting service. All IR commands between frequencies of 30-100 kHz are passed, ensuring compatibility with nearly every IR system and source component on the market. A 3.5 mm mono plug has been attached to the 10 ft. control cable for quick connection to a Audtek Electronics hub such as the small WHIRH IR hub or WHIRDH wall plate IR hub.
Specifications: • IR frequency bandwidth: 30-100 kHz • 10 ft. control cable • Dimensions: 1" H x 0.63" W x 0.375" D. Note: Audtek Electronics IR hub, 12 VDC power supply, multi-conductor wire, and Audtek Electronics target required for proper operation. Designed to be placed adjacent to equipment under control. Do not place directly on source components.
  • BrandAudtek Electronics
  • ModelWHIREB
  • Part Number182-882
  • UPC844632070327
  • Product CategoryIR Emitters
    (5 Reviews)
  • Weight0.09 lbs.
View similar products to the Audtek Electronics WHIREB IR Emitter Blaster
in the IR Emitters product category.
