Audtek Electronics WHIR3505 Tube Style Wide-Band IR Repeater Target
Brand:|Model: WHIR3505|Part # 182-880
Audtek Electronics' WHIR3505 tube style IR target maintains the aesthetic of a clean, hidden source component installation while keeping you in control. A wide frequency response makes it compatible with nearly every IR product on the market.
Wired Home is now Audtek
List Price$103.99
You Save45%
$57.48
Buy 4+$54.74
Part # 182-880
  • Wide-band 30-100 kHz frequency response
  • Industry standard tube target design
  • Hide an IR target anywhere
  • Fits into a 1/2" hole
  • Compatible with nearly every piece of IR equipment on the market
Many homes today are outfitted with hidden source equipment, be it in cabinets, closets, or the basement. In order to remain in control of your components, an IR distribution system is needed. To maintain décor aesthetics, the engineers at Audtek Electronics have developed the WHIR3505. Wide-band frequency response enables compatibility with nearly every infrared device available on the market, and this IR tube style target is smaller in diameter than a penny. Two target caps; one brass and one plastic, with deep-purple lenses allowing this target to be placed nearly anywhere while remaining unobtrusive. Brass construction ensures durability. With the use of economical Cat 5 cable, this target may be mounted up to 1,000 ft. from an IR hub.
Specifications: • IR frequency bandwidth: 30-100 kHz • Control range: 30 ft. • Reception angle: ±45° off-axis • Dimensions: 0.6" dia x 0.24" L (head), 0.43" dia. x 1.9" L (body) • 6 ft. control cable. Note: Audtek Electronics IR hub, 12 VDC power supply, multi-conductor wire, and Audtek Electronics emitters required for proper operation.
  • Mounting StyleTube Style
  • BrandAudtek Electronics
  • ModelWHIR3505
  • Part Number182-880
  • UPC844632070310
  • Product CategoryIR Targets
    (3 Reviews)
  • Weight0.15 lbs.
View similar products to the Audtek Electronics WHIR3505 Tube Style Wide-Band IR Repeater Target
in the IR Targets product category.
