Audtek Electronics IRE2 Dual IR Emitter with Confirmation LED
Brand:|Model: IRE2|Part # 182-841
Audtek Electronics emitters are an attractive, affordable way to finish your distributed IR system.
Wired Home is now Audtek
List Price$9.99
You Save33%
$6.68
Buy 4+$6.34
Part # 182-841
  • 2 emitters on one plug simplify installation or allow for using more devices from one repeater hub
  • Elegant design and compact size
  • Built-in confirmation LED
  • Infrared passive, deep-purple shell
  • Compatible with 12 VDC IR repeater systems
The Audtek Electronics IRE2 offers excellent flexibility for distributed IR systems. The deep-purple shell passes infrared so you can use your remote control even with the emitter in place. With a 10 ft. long cable, it's easy to route the IRE2 in, around, and through your AV system to control the necessary device. Utilizing a standard 3.5 mm plug, this IR emitter is compatible with most IR systems. To install, simply peel off the adhesive backing and stick the emitter over your AV device's IR target. You will know that the emitter is repeating a signal when you see the confirmation LED flashing.
Specifications: • Power: 12 VDC • Dimensions: 15 mm (L) x 10 mm (W) x 6 mm (H) • Connector: 3.5 mm, 2-conductor (mono) • Cord length: 10 ft. • Color: Deep-purple • Wavelength: 635-640 nm
  • BrandAudtek Electronics
  • ModelIRE2
  • Part Number182-841
  • UPC848864000381
  • Product CategoryIR Emitters
  • Weight0.1 lbs.
View similar products to the Audtek Electronics IRE2 Dual IR Emitter with Confirmation LED
in the IR Emitters product category.
