181-554_ALT_0
181-554_ALT_1
181-554_ALT_2
181-554_ALT_3
181-554_ALT_4
181-554_ALT_5
181-554_ALT_6
181-554_ALT_7
181-554_ALT_9
Audtek Electronics HR1403 3 ft. High Speed 4K HDMI Cable CL2 Rated 10.2 Gbps
Brand:|Model: HR1403|Part # 181-554
This Audtek Electronics 3 ft. HR1403 HDMI cable is built for the latest HDMI technology, featuring bi-directional Ethernet Channel (HEC), Audio Return Channel (ARC), 3D support, deep color, and resolutions up to 1080p.
This High-Speed HDMI Cable is available in the following lengths:
1 ft.   2 ft.   3 ft.   6 ft.   9 ft.   12 ft.   18 ft.   25 ft.   35 ft.   50 ft.
Wired Home is now Audtek
List Price$4.99
You Save40%
$2.99
Buy 4-24 $2.88
Buy 25+$2.76
Part # 181-554
  • Transmits digital audio/video signals up to 10.2 Gbps to support 4K resolutions
  • Bi-directional Ethernet Channel (HEC) for internet connection
  • Audio Return Channel (ARC) to feed audio from TV to AV receiver
  • Capable of high-resolution video up to 1080p
  • High transfer rates support 3D and deep color
  • CL2 rated PVC jacket to run behind walls
  • Lifetime warranty
The magic of HDMI is its ability to transmit huge amounts of information through one small cable. Audtek Electronics cables are simply manufactured using processes and materials necessary to guarantee the signal sent through the cable will remain intact and unaltered, resulting in the most enjoyable HDTV viewing experience possible. These cables achieve the capabilities of HDMI Version 1.4, covering all the support you need for modern home entertainment technology.
Reduce your cables and increase your connections.
Now that TVs are able to connect to the Internet, why bother connecting everything else individually? Audtek Electronics HDMI cables offer bi-directional HDMI Ethernet Channel (HEC) that allows you to share the network connection between devices. Use this cable with your gaming console, digital media receiver, Blu-ray player, or DVR to connect to your TV's network connection, along with audio and video transfer.
When using an antenna or a network based application within your TV, the audio source starts at the TV. Instead of running a cable to the receiver for audio, you can now run it through a Audtek Electronics HDMI cable, which is also sending video to the TV. The Audio Return Channel (ARC) functionality in these cables allows you to do this – reducing your cable count and simplifying your home entertainment system.
High speed transfer rates support the latest in HDMI technology.
Due to the impressive construction quality on Audtek Electronics HDMI cables, they are capable of high speed transfer rates. These transfer rates mean that you can get high resolutions up to 1080p, deep color (30/36/48-bit), and supports 3D technology.
High quality cables deserve high quality protection.
Audtek Electronics provides efficient signal transfer by using high quality materials for cable construction. Oxygen free 28 AWG copper conductors are triple shielded with Mylar foil to make sure your signal travels quickly and uninterrupted. Connectors are plated with 24 karat gold to provide excellent conduction. The outside PVC jacket is CL2 rated for proper installation behind walls. The low profile connector and flexible jacket makes routing these cables much easier. Cable is packaged in simple, recyclable, easy to open packaging. Lifetime warranty.
  • Cable TypeHDMI Male to Male
  • Cable Length3.0 ft.
  • Jacket ColorBlack
  • Wire Gauge28 AWG
  • Special FeaturesCL2 Rated
  • BrandAudtek Electronics
  • ModelHR1403
  • Part Number181-554
  • UPC848864007885
  • Product CategoryHDMI Cables
    (1 Reviews)
  • Weight0.1500 lbs.
View similar products to the Audtek Electronics HR1403 3 ft. High Speed 4K HDMI Cable CL2 Rated 10.2 Gbps
in the HDMI Cables product category.
