Audtek Electronics 205E6Y Cat 5e Shielded CMR Solid 350 MHz Blue 500 ft.
Brand:|Model: 205E6Y|Part # 101-029
Audtek Electronics' shielded Cat 5e bulk cable features a 125% overlapped Mylar wrap over four twisted pair conductors, for virtual immunity from electro-magnetic and radio frequency interference.
Wired Home is now Audtek
List Price$174.99
You Save53%
$81.86
Buy 4+$79.41
Part # 101-029
  • High noise-rejection design eliminates interference
  • 125% overall Mylar wrap provides maximum signal protection
  • Shielded twisted-pair cable construction with a single drain wire for easy connections
  • 350 MHz bandwidth far exceeds 100 MHz bandwidth of standard Cat 5e
  • Sequential foot markers indicate cable remaining in the box
Audtek Electronics' shielded category 5e cable overcomes electrically noisy environments, common in industrial settings, to provide a clear and undistorted signal path for computer, telephone, and surveillance networks. The cable's aluminized Mylar shield employs an easily-connected single tinned-copper drain wire to route noise to ground.
A 350 MHz cable bandwidth allows for advanced applications, including high-speed Ethernet networks and A/V signal transmission using baluns (including HDTV quality signals). Also meets or exceeds the standards set forth by EIA/TIA 568B.2 for performance and UL and NEC riser rating requirements for vertical flame testing. The cable's Spool-in-Box payout system saves installers time and money by virtually eliminating performance-robbing cable kinks (common with other manufacturers' bulk Cat 5e cable) during installation.
Specifications: • Individual conductors: 24 AWG (0.52 mm dia.) solid copper • Drain wire: 0.4 mm dia. tinned-copper • Nominal impedance: 100 ohms (±15 ohms) • DCR: 8.9 ohms/100 meters • Capacitance: 4800 pF/100 meters • Attenuation @ 350 MHz: 44.9 dB • Overall cable diameter: 6.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Special FeaturesShielded
  • Wire Gauge24 AWG
  • Jacket ColorBlue
  • Length500 ft.
  • BrandAudtek Electronics
  • Model205E6Y
  • Part Number101-029
  • UPC844632071584
  • Product CategoryCat 5e / Cat 6 Network Cable
    (3 Reviews)
  • Weight15.65 lbs.
View similar products to the Audtek Electronics 205E6Y Cat 5e Shielded CMR Solid 350 MHz Blue 500 ft.
in the Cat 5e / Cat 6 Network Cable product category.
