Audtek Electronics 105E6Y Cat 5e CMR Solid Cond 350 MHz Blue 500 ft.
Brand:|Model: 105E6Y|Part # 101-005
Audtek Electronics' bulk Cat 5e cable features 350 MHz bandwidth for high-speed Gigabit Ethernet networks while meeting or exceeding the standards set forth by EIA/TIA 568B.2 for performance. Complies with UL and NEC riser rating requirements for vertical flame testing.
Wired Home is now Audtek
List Price$123.99
You Save50%
$62.19
Buy 4+$60.32
Part # 101-005
  • Unshielded quad twisted pair construction
  • Ideal for computer network, voice, video, sound
  • 350 MHz rating far exceeds the performance of standard 100 MHz Cat 5e
  • Spool-in-Box payout system virtually eliminates cable kinks, works with cable caddies
  • Sequential marks every two feet show remaining cable at-a-glance
  • CMR rated, UL, and C-UL listed; verified EIA/TIA 568B.2 compliant
Category 5e cable has become the standard cable type used in commercial and residential structured wire systems for telephony, computer networking, and surveillance…and more! Audtek Electronics' bulk Cat 5e features 350 MHz bandwidth for advanced applications, including high-speed Gigabit Ethernet (1000BASE-T) networks and A/V signal transmission using baluns. Meets or exceeds the standards set forth by EIA/TIA 568B.2 for performance, as well as UL and NEC riser rating requirements for vertical flame testing.
Audtek Electronics Cat 5e cable's packaging was designed around the Spool-in-Box payout system. This saves installers time and money by virtually eliminating performance-robbing cable kinks (common with other manufacturers' bulk Cat 5e cable) during installation. Alternatively, the internal spool may be removed to "rack-up" on a traditional cable caddy.
Specifications: • Individual conductors: 24 AWG (0.50 mm) • Nominal impedance: 100 ohms (±15 ohms) • DCR: 9 ohms/100 meters • Capacitance: 5000 pF/100 meters • Attenuation @ 350 MHz: 44.9 dB • Overall cable diameter: 5.10 mm (± 0.10 mm).
  • Cable Rating CMR Rated
  • Wire Gauge24 AWG
  • Jacket ColorBlue
  • Length500 ft.
  • BrandAudtek Electronics
  • Model105E6Y
  • Part Number101-005
  • UPC844632071522
  • Product CategoryCat 5 / Cat 6 Network Cable
    (3 Reviews)
  • Weight13.7 lbs.
View similar products to the Audtek Electronics 105E6Y Cat 5e CMR Solid Cond 350 MHz Blue 500 ft.
in the Cat 5 / Cat 6 Network Cable product category.
