Audio-Technica U891RCX Cardioid Condenser Boundary Microphon
Brand:|Model: U891RCX|Part # 242-4946
A wide range condenser microphone with a cardioid polar pattern, the ultra-smart U891RC is equipped with local or remote switching options. The mic is equipped with an 80 Hz low-cut UniSteep® filter to reduce pickup of low-frequency ambient noise.
ORDER TODAY
Ships in 5-7 business days
$319.00
Part # 242-4946
  • External contact closure capability permits control of remote devices from microphone switch
  • External LED control allows for accurate depiction of the live status of the microphone
  • UniPoint® capsule near boundary eliminates phase distortion & delivers clear performance
  • Heavy die-cast case and non-slip silicon foam bottom pads minimize coupling of surface vibration
  • Low-profile design with low-reflectance black finish for minimum visibility
A wide range condenser microphone with a cardioid polar pattern, the ultra-smart U891RC is equipped with local or remote switching options. For flexible control in conference and boardroom installations, the unit's external contact closure ability allows a user to trigger an external device-a camera, for instance-from a switch on the microphone. Another ease-of-use feature: the microphone's electronic on-off switch can be set to three operating modes: touch-on/touch-off, press to talk, and press to mute. The mic is also equipped with an 80 Hz low-cut UniSteep® filter to reduce pickup of low-frequency ambient noise. Its red LED status indicator can be controlled remotely. UniGuard® innovations offer unsurpassed immunity from radio frequency interference; a unique rotating PivotPoint® connector changes the cable exit point-no tools required. It requires 11 to 52V DC phantom power, which operates the microphone and switch circuitry. Included furnished accessory: soft protective pouch.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Half-cardioid (cardioid in hemisphere above mounting surface) • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –34 dB (19.9 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum Input sound level: 130 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 104 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 68 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 4 mA typical • Switches: Touch-sensitive control: on/off; Switch function: touch on/off, momentary on, momentary off; Control: local, remote, LED remote; Flat, roll-off • Dimensions: 4.25" (108.0 mm) long, 3.31" (84.0 mm) maximum width, 0.91" (23.0 mm) height • Output connector: TB5M-type • Cable: 25 ft. (7.6 m) long, 0.13" (3.2 mm) diameter, 5-conductor shielded cable (2 conductors under shield; 3 control wires outside shield); TA5F-type connector at microphone end, output end stripped and tinned for connection to electronic device • Accessories furnished: Soft protective pouch.
  • BrandAudio-Technica
  • ModelU891RCX
  • Part Number242-4946
  • UPC042005165889
  • Product CategoryBoundary / PZM / Surface Microphones
  • Weight1.1 lbs.
View similar products to the Audio-Technica U891RCX Cardioid Condenser Boundary Microphon
in the Boundary / PZM / Surface Microphones product category.
