Audio-Technica U859QL Condenser Gooseneck Microphone
Brand:|Model: U859QL|Part # 242-4940
Designed to plug directly into a panel- or desk-mounted XLRF-type connector, the 18.9" long microphone features an ultra-flexible small-diameter gooseneck and accepts interchangeable elements.
ORDER TODAY
Ships in 5-7 business days
List Price$210.00
You Save29%
$149.00
Part # 242-4940
  • Designed for high-quality sound reinforcement, professional recording and broadcasting
  • Easy-to-adjust, rugged, small-diameter, alternating gooseneck
  • UniSteep® filter provides a steep low-frequency attenuation to improve sound pickup
  • Self-contained electronics eliminate need for external power module
Designed to plug directly into a panel- or desk-mounted XLRF-type connector, the 18.9" long microphone features an ultra-flexible small-diameter gooseneck and accepts interchangeable elements. Equipped with self-contained electronics, the phantom-powered microphone also offers an 80 Hz low-cut UniSteep® filter that reduces pickup of low-frequency ambient noise. Quick-mount design with 3-pin XLRM-type connector insert at base plugs into any standard XLRF-type surface or cable connector. Included furnished accessory: AT8153 two-stage foam windscreen.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 100-16,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –43 dB (7.0 mV) re 1V at 1 Pa • Impedance: 250 ohms • Maximum input sound level: 140 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 111 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 65 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Switch: Flat, roll-off • Dimensions: 18.90" (480.0 mm) long, 0.48" (12.3 mm) head diameter, 0.74" (18.9 mm) base diameter • Output connector: Integral 3-pin XLRM-type.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelU859QL
  • Part Number242-4940
  • UPC042005140855
  • Product CategoryGooseneck / Podium Microphones
  • Weight0.82 lbs.
View similar products to the Audio-Technica U859QL Condenser Gooseneck Microphone
in the Gooseneck / Podium Microphones product category.
