Audio-Technica U857RU UniLine Line-Cardioid Gooseneck Mic
Brand:|Model: U857RU|Part # 242-4938
Featuring Audio-Technica's UniLine™ line-cardioid element, the U857RU adapter-mount gooseneck condenser microphone has a small-diameter gooseneck with virtually no "memory." The microphone direct mounts to any 5/8"-27 stand; it is 16.81" long.
  • Designed for high-quality sound reinforcement, professional recording and broadcasting
  • UniLine™ polar pattern provides narrow 90° acceptance angle
  • Easy-to-adjust, rugged, small-diameter, alternating gooseneck with virtually no "memory"
  • UniSteep® filter provides a steep low-frequency attenuation to improve sound pickup
  • Accepts interchangeable elements to permit angle of acceptance from 90° to 360°
Featuring Audio-Technica's UniLine™ line-cardioid element, the U857RU adapter-mount gooseneck condenser microphone has a small-diameter gooseneck with virtually no "memory." Its ultra-flexible, robust design permits easy adjustment into desired shape while resisting inadvertent repositioning. The microphone direct mounts to any 5/8"-27 stand; it is 16.81" long. Equipped with UniGuard® innovations that offer unsurpassed immunity from radio frequency interference, the U857RU accepts interchangeable elements, available in cardioid, hypercardioid, omnidirectional and UniLine™ line cardioid polar patterns. The phantom-powered microphone also offers an 80 Hz low-cut UniSteep® filter that reduces pickup of low-frequency ambient noise.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Line cardioid • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –35 dB (17.7 mV) re 1V at 1 Pa • Impedance: 250 ohms • Maximum input sound level: 135 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 115 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 74 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Switch: Flat, roll-off • Dimensions: Microphone 16.81" (427.0 mm) long, 0.48" (12.2 mm) head diameter; Power Module 3.66" (92.9 mm) long, 0.74" (18.9 mm) diameter • Output connector: Integral 3-pin XLRM-type • Cable: 9.8 ft. (3.0 m) long (permanently attached to microphone), 0.13" (3.2 mm) diameter, 2-conductor, shielded cable with TA3F-type connector • Optional interchangeable elements: UE-C cardioid (120°); UE-H hypercardioid (100°); UE-O omnidirectional (360°) • Accessories furnished: AT8538 power module
  • BrandAudio-Technica
  • ModelU857RU
  • Part Number242-4938
  • UPC042005140787
  • Product CategoryGooseneck / Podium Microphones
  • Weight1.2 lbs.
View similar products to the Audio-Technica U857RU UniLine Line-Cardioid Gooseneck Mic
in the Gooseneck / Podium Microphones product category.
