Audio-Technica U857QL Cardioid Condenser Microphone
Brand:|Model: U857QL|Part # 242-4926
The 18.94" version of the U857Q, the U857QL cardioid condenser quick-mount gooseneck microphone is designed to plug directly into a panel- or desk-mounted XLRF-type connector.
ORDER TODAY
Ships in 5-7 business days
List Price$275.00
You Save28%
$199.00
Part # 242-4926
  • Designed for high-quality sound reinforcement, professional recording and broadcasting
  • Easy-to-adjust, rugged, small-diameter, alternating gooseneck
  • UniSteep® filter provides a steep low-frequency attenuation to improve sound pickup
  • Self-contained electronics eliminate need for external power module
  • Accepts interchangeable elements to permit angle of acceptance from 90° to 360°
The 18.94" version of the U857Q, the U857QL cardioid condenser quick-mount gooseneck microphone is designed to plug directly into a panel- or desk-mounted XLRF-type connector. The microphone offers unsurpassed immunity from radio frequency interference thanks to UniGuard® innovations. It features an ultra-flexible small-diameter gooseneck and accepts interchangeable elements. Equipped with self-contained electronics, the phantom-powered microphone also offers an 80 Hz low-cut UniSteep® filter that reduces pickup of low-frequency ambient noise. Quick-mount design with 3-pin XLRM-type connector insert at base plugs into any standard XLRF-type surface or cable connector. Included furnished accessories: AT8153 two-stage foam windscreen and an AT8662 shock mount.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –39 dB (11.2 mV) re 1V at 1 Pa • Impedance: 250 ohms • Maximum input sound level: 139 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 115 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 70 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Switch: Flat, roll-off • Dimensions: 18.94" (481.0 mm) long, 0.48" (12.2 mm) head diameter, 0.74" (18.9 mm) base diameter • Output connector: Integral 3-pin XLRM-type • Optional interchangeable elements: UE-H hypercardioid (100°); UE-O omnidirectional (360°); UE-UL UniLine™ (90°).
  • BrandAudio-Technica
  • ModelU857QL
  • Part Number242-4926
  • UPC042005140831
  • Product CategoryGooseneck / Podium Microphones
    (1 Reviews)
  • Weight0.96 lbs.
View similar products to the Audio-Technica U857QL Cardioid Condenser Microphone
in the Gooseneck / Podium Microphones product category.
