Audio-Technica U857AL Cardioid Condenser Gooseneck Mic
Brand:|Model: U857AL|Part # 242-4918
This cardioid condenser gooseneck microphone direct mounts to any 5/8"-27 stand; it is 16.58" long.
  • Designed for high-quality sound reinforcement, professional recording and broadcasting
  • Easy-to-adjust, rugged, small-diameter, alternating gooseneck with virtually no "memory"
  • UniSteep® filter provides a steep low-frequency attenuation to improve sound pickup
  • Accepts interchangeable elements to permit angle of acceptance from 90° to 360°
  • Two-stage foam windscreen yields dramatically improved resistance to P-pops and other breath blasts
Engineered for versatile positioning and extremely flexible performance in boardroom, school, government, house-of-worship and other installed applications, the U857AL features a small-diameter gooseneck with virtually no "memory." Its ultra-flexible, robust design permits easy adjustment into desired shape while resisting inadvertent repositioning. This cardioid condenser gooseneck microphone direct mounts to any 5/8"-27 stand; it is 16.58" long. Equipped with UniGuard® innovations that offer unsurpassed immunity from radio frequency interference, the U857AL accepts interchangeable elements, available in cardioid, hypercardioid, omnidirectional and UniLine™ line cardioid polar patterns. The battery- or phantom-powered microphone also offers an 80 Hz low-cut UniSteep® filter that reduces pickup of low-frequency ambient noise.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: Phantom –42 dB (7.9 mV) re 1V at 1 Pa; Battery –43 dB (7.0 mV) re 1V at 1 Pa • Impedance: Phantom 200 ohms; Battery 270 ohms • Maximum input sound level: Phantom 133 dB SPL, 1 kHz at 1% THD; Battery 123 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): Phantom 109 dB, 1 kHz at Max SPL; Battery 99 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 70 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Battery type: 1.5V AA/UM3 • Battery current/life: 0.4 mA / 1200 hours typical (alkaline) • Switch: Off, on-flat, on-roll-off • Dimensions: Microphone 16.58" (421.0 mm) long, 0.48" (12.2 mm) diameter; Power module 3.31" (84.0 mm) H x 2.48" (63.0 mm) W x 0.87" (22.0 mm) D • Output connector (power module): Integral 3-pin XLRM-type • Cable: 9.8 ft. (3.0 m).
  • BrandAudio-Technica
  • ModelU857AL
  • Part Number242-4918
  • UPC042005140756
  • Product CategoryGooseneck / Podium Microphones
  • Weight0.8 lbs.
View similar products to the Audio-Technica U857AL Cardioid Condenser Gooseneck Mic
in the Gooseneck / Podium Microphones product category.
