Audio-Technica U853PMWU Uniline Line-Cardioid Hanging Mic
Brand:|Model: U853PMWU|Part # 242-4908
The white-finished version of U853PMU, the U853PMWU UniLine condenser hanging microphone features Audio-Technica’s UniLine® line-cardioid element and comes equipped with a wall/ceiling plate power module for permanent installation in a standard, single-gang electrical box.
ORDER TODAY
Ships in 5-7 business days
List Price$329.00
You Save18%
$269.00
Part # 242-4908
  • Designed for suspension over choirs, instrumental groups and theater stages
  • UniLine® polar pattern provides narrow 90° acceptance angle
  • UniSteep® filter provides a steep low-frequency attenuation to improve sound pickup
  • Accepts interchangeable elements to permit angle of acceptance from 90° to 360°
  • Low-profile design with low-reflectance finish for minimum visibility
The white-finished version of U853PMU, the U853PMWU UniLine condenser hanging microphone features Audio-Technica’s UniLine® line-cardioid element and comes equipped with a wall/ceiling plate power module for permanent installation in a standard, single-gang electrical box. The phantom-powered microphone is equipped with UniGuard® innovations that offer unsurpassed immunity from radio frequency interference. It accepts interchangeable elements, available in cardioid, hypercardioid, omnidirectional and UniLine™ line cardioid polar patterns. Its 80 Hz low-cut UniSteep® filter reduces pickup of low-frequency ambient noise.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Line cardioid • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –35 dB (17.7 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 124 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 102 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 72 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 4 mA typical • Switch: Flat, roll-off; 0 dB/+10 dB gain setting • Dimensions: Microphone 6.14" (156.0 mm) long, 0.48" (12.2 mm) diameter; Power module 2.80" (71.0 mm) W x 4.55" (115.5 mm) H x 1.42" (36.0 mm) D • Output connector (power module): Screw terminals • Cable: 25.0 ft. (7.6 m) long (permanently attached to microphone), 0.13" (3.2 mm) diameter, 2-conductor, shielded cable with TA3F-type connector • Optional interchangeable elements: UE-C cardioid (120°); UE-H hypercardioid (100°); UE-O omnidirectional (360°) • Accessories furnished: AT8154(WH) two-stage foam windscreen, AT8451(WH) steel hanger, AT8534 wall/ceiling plate power module, AT8438 5/8"-27 stand adapter • Audio-Technica case style: M32.
  • BrandAudio-Technica
  • ModelU853PMWU
  • Part Number242-4908
  • UPC042005140749
  • Product CategoryHanging / Choir Microphones
  • Weight1 lbs.
View similar products to the Audio-Technica U853PMWU Uniline Line-Cardioid Hanging Mic
in the Hanging / Choir Microphones product category.
