Audio-Technica U851RW Cardioid Condenser Boundary Mic White
Brand:|Model: U851RW|Part # 242-4892
The white-finished version of the U851R, the phantom-powered U851RW features a PivotPoint® rotating output connector, UniSteep® filter and UniGuard® RFI-shielding technology.
ORDER TODAY
Ships in 3-10 business days
$219.00
Part # 242-4892
  • Designed for surface-mount applications such as sound reinforcement, pro recording, tv, and more
  • PivotPoint® rotating output connector allows cable to exit fromrear or the bottom of the microphone
  • Self-contained electronics eliminate need for external power module
  • Small-diameter UniPoint® capsule near boundary eliminates phase distortion
  • Heavy die-cast case and non-slip silicon foam bottom pads minimize coupling of surface vibration
The white-finished version of the U851R, the phantom-powered U851RW features a PivotPoint® rotating output connector, UniSteep® filter and UniGuard® RFI-shielding technology. Offering outstanding speech intelligibility and transparent sound quality for surface-mount applications, the U851RW accepts interchangeable condenser elements—available for boundary microphones in cardioid, hypercardioid and omnidirectional polar patterns. With a heavy die-cast case and silicon foam bottom pads to minimize coupling of surface vibration to the microphone, the U851RW is equipped with self-contained electronics, eliminating the need for an external power module.
Specifications: • Element: Fixed-charge back plate permanently polarized condenser • Polar pattern: Half-cardioid (cardioid in hemisphere above mounting surface) • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –34 dB (19.9 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 134 dB SPL, 1 kHz at 1% THD • Dynamic Range (typical): 108 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 68 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 4 mA typical • Switch: Flat, roll-off • Dimensions: 4.25" L x 3.31" W x 0.91" H (108 x 84 x 23 mm) • Output connector: TB3M-type • Cable: 25 ft. (7.6 m) long, 0.13" (3.2 mm) diameter, 2-conductor, shielded cable with TA3F and XLRM-type connectors • Optional interchangeable elements: UE-H hypercardioid (100°); UE-O omnidirectional (360°) • Accessories furnished: Soft protective pouch.
  • BrandAudio-Technica
  • ModelU851RW
  • Part Number242-4892
  • UPC042005139156
  • Product CategoryBoundary / PZM / Surface Microphones
  • Weight1.3 lbs.
View similar products to the Audio-Technica U851RW Cardioid Condenser Boundary Mic White
in the Boundary / PZM / Surface Microphones product category.
