Audio-Technica U851R Cardioid Condenser Boundary Microphone
Brand:|Model: U851R|Part # 242-4890
Featuring breakthrough audio and mechanical design innovations, the phantom-powered U851R offers outstanding speech intelligibility and transparent sound quality for surface-mount applications.
$219.00
Part # 242-4890
  • UniGuard® RFI-shielding technology offers excellend rejection of radio frequency interference
  • Self-contained electronics eliminate need for external power module
  • UniPoint® capsule near boundary eliminates phase distortion & delivers high-output performance
  • Heavy die-cast case and non-slip silicon foam bottom pads minimize coupling of surface vibration
  • Low-profile design with low-reflectance finish for minimum visibility
  • Phantom-power-only version of the U851A
Featuring breakthrough audio and mechanical design innovations, the phantom-powered U851R offers outstanding speech intelligibility and transparent sound quality for surface-mount applications. The microphone is equipped with a PivotPoint® rotating output connector, UniSteep® filter and UniGuard® RFI-shielding technology. PivotPoint® rotating output connector allows cable to exit from either the rear or the bottom of the microphone. The U851R accepts interchangeable condenser elements-available for boundary microphones in cardioid, hypercardioid and omnidirectional polar patterns. With a heavy die-cast case and silicon foam bottom pads to minimize coupling of surface vibration to the microphone, the U851R is equipped with self-contained electronics, eliminating the need for an external power module. Designed for surface-mount applications such as high-quality sound reinforcement, professional recording, television, conferencing and other demanding sound pickup situations.
Specifications: • Element: Fixed-charge back plate permanently polarized condenser • Polar pattern: Half-cardioid (cardioid in hemisphere above mounting surface) • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –34 dB (19.9 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 134 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 108 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 68 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 4 mA typical • Switch: Flat, roll-off • Dimensions: 4.25" (108.0 mm) long, 3.31" (84.0 mm) maximum width, 0.91" (23.0 mm) height • Output connector: TB3M-type • Cable: 25 ft. (7.6 m) long, 0.13" (3.2 mm) diameter, 2-conductor, shielded cable with TA3F and XLRM-type connectors • Optional interchangeable elements: UE-H hypercardioid (100°); UE-O omnidirectional (360°).
  • BrandAudio-Technica
  • ModelU851R
  • Part Number242-4890
  • UPC042005139149
  • Product CategoryBoundary / PZM / Surface Microphones
  • Weight1.3 lbs.
View similar products to the Audio-Technica U851R Cardioid Condenser Boundary Microphone
in the Boundary / PZM / Surface Microphones product category.
