242-4874_ALT_0
242-4874_ALT_1
Audio-Technica PRO 70 Lavalier/Instrument Condenser Mic
Brand:| Model: PRO 70
The PRO 70 is designed to make music and speech clearly and comfortably audible, yet never draw attention to itself or its operation. The microphone is equipped with a low-frequency roll-off switch that allows for reduced pickup of room noise.
  • Miniature condenser microphone is ideal for both vocal and acoustic guitar applications
  • Natural and articulate vocal reproduction when used as a clip-on lavalier—clothing clip included
  • Excels in pickup of acoustic guitar with included instrument adapter
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • Switchable low-frequency roll-off
  • Corrosion-resistant contacts from gold-plated XLRM-type connector
  • Operates on battery or phantom power
242-4874
Weight: 0.9 lbs.
ORDER TODAY
Ships in 5-7 business days
List Price$209.00
You Save34%
$137.79
Part # 242-4874
This miniature condenser microphone achieves full-sounding pickup and is known for outstanding consistency and dependable performance. Supplied with both a clothing clip and guitar mount, it provides natural and articulate vocal reproduction when used as a clip-on lavalier and excels in pickup of acoustic guitar. The PRO 70 is designed to make music and speech clearly and comfortably audible, yet never draw attention to itself or its operation. The microphone is equipped with a low-frequency roll-off switch that allows for reduced pickup of room noise. The versatile PRO 70 may be powered by either battery or phantom power. Its cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of the desired sound source. Included furnished accessories: AT8411 clothing clip, AT8444 instrument adapter, power module, windscreen, battery, and a soft protective pouch.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 100-14,000 Hz • Low frequency roll-off: 80 Hz, 8 dB/octave • Open circuit sensitivity: Phantom -45 dB (5.6 mV) re 1V at 1 Pa; Battery -45 dB (5.6 mV) re 1V at 1 Pa • Impedance: Phantom 200 ohms; Battery 200 ohms • Maximum input sound level: Phantom 123 dB SPL, 1 kHz at 1% THD; Battery 123 dB SPL, 1 kHz at 1% THD • Dynamic Range (typical): Phantom 96 dB, 1 kHz at Max SPL; Battery 96 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 67 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Battery type: 1.5V AA/UM3 • Battery current life: 0.4 mA / 1200 hours typical (alkaline) • Switch: Off, on-flat, on-roll-off • Dimensions: Microphone 0.98" (25.0 mm) long, 0.40" (10.2 mm) diameter; Power module 3.27" (83.0 mm) H x 2.48" (63.0 mm) W x 0.87" (22.0 mm) D • Output connector: Integral 3-pin XLRM-type • Cable: Integral 6 ft. (1.8 m), permanently attached between microphone and power module.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelPRO 70
  • Part Number242-4874
  • UPC042005134342
  • Product CategoryInstrument Microphones
  • Weight0.9 lbs.
View similar products to the Audio-Technica PRO 70 Lavalier/Instrument Condenser Mic
in the Instrument Microphones product category.
Customer projects that include: Audio-Technica PRO 70 Lavalier/Instrument Condenser Mic
