Audio-Technica PRO-501/G Pro Series 5 UHF Wireless Guitar & Instrument System
Brand:|Model: PRO-501/G|Part # 242-5186
Pro Series 5 Wireless Systems are designed with the serious performer in mind. Standard features include quick and easy set up, rugged construction, and of course, the crystal clear sound quality upon which Audio-Technica has built their formidable reputation.
  • 8 selectable frequency-coordinated UHF channels
  • Use up to 8 simultaneous systems - all channels compatible
  • Automatic frequency scanning
  • Diversity operation for increased range/reliability
  • Balanced XLR and unbalanced ¼” output connectors
Audio-Technica's Pro Series 5 Wireless Systems deliver outstanding sound quality, automatic frequency scanning, and a convenient custom case for storage and use on the road. Perfect for the serious performer on the go, yet affordable enough for musicians at virtually any level.
These easy-to-use wireless systems feature eight user-selectable frequency-coordinated channels, diversity operation for increased range and reliability, automatic frequency scanning, Tone Lock™ squelch and more. Up to eight systems can be used simultaneously without competing for the same frequency. Pro Series 5 systems come equipped with your choice of handheld, headworn, or lavalier microphones, body-pack only, or choose a system designed for guitar or other Hi-Z instrument hookup.
All Pro Series 5 systems include the PRO-R500 receiver, which features antenna-switching diversity reception. Advanced logic circuitry monitors reception, selecting the superior signal from two antennae, providing you with better sound quality and greatly reducing the possibility of interference and dropouts. Soft-touch controls provide convenient access to selection of operating frequency and automatic scanning, while an easy-to-read LED display indicates selected channel and scanning operation, plus Antenna and AF Peak indicators. You have your choice of balanced XLR or unbalanced 1/4" output connectors for maximum versatility, and Audio-Technica's exclusive Tone Lock™ squelch technology virtually eliminates noise and interference when the transmitter is not engaged.
The PRO-501/G system includes the versatile PRO-T501 UniPak® body-pack transmitter with the AT-GcW guitar/instrument cable. The UniPak® transmitter offers separate trim controls for guitar and microphone, plus switchable high and low RF power settings. Pro Series 5 body-pack systems are compatible with all Audio-Technica Wireless Essentials® microphones and cables, and other microphones using the 4-pin locking-style connector, which makes it great for sound reinforcement pros as well.
Overall System Specifications: • UHF operating frequency: 542.125 to 561.250 MHz • Number of channels: 8 • Frequency stability: ± 0.005% • Modulation mode: FM • Frequency response: 100 - 12,000 Hz • Range: 200 feet (60m) typical (open range line-of-sight environment with no interfering signals) • Operating temperature range: 40° to 110° F (4° to 43° C) Note: battery performance may be affected at very low temperatures.
Receiver Specifications: • Receiving system: Antenna-switching diversity • Image rejection: 55 dB minimum • S/N ratio: >80 dB @ 10 kHz deviation (IEC-weighted), maximum deviation 25 kHz • Audio outputs: 1/4" unbalanced (211 mV / -13.5 dB); XLR balanced (150 mV / -16.5 dB) • Power supply (included): 100-240 VAC 50/60 Hz • Dimensions: 7.48" W x 1.65" H x 5.12" D (190 x 42 x 130 mm) • Weight: 12.9 oz. (365 g).
UniPak® Transmitter Specifications: • RF power output: 10mW (high); 5mW (low), typical • Input connector: 4-pin locking (pin 1 - GND; pin 2 - instrument input; pin 3 - microphone input; pin 4 - DC bias +9V) • Battery: Two (2) AA alkaline (not included) • Battery life: 8 hours (high); 10 hours (low) typical (depending on battery type and usage pattern) • Dimensions: 2.56" W x 4.13" H x 0.73" D (65 x 105 x 18.5 mm) • Weight: 2.8 oz. (78 g) without batteries.
  • Frequency BandUHF
  • BrandAudio-Technica
  • ModelPRO-501/G
  • Part Number242-5186
  • UPC042005176441
  • Product CategoryGuitar & Instrument Wireless Systems
  • Weight4.5 lbs.
View similar products to the Audio-Technica PRO-501/G Pro Series 5 UHF Wireless Guitar & Instrument System
in the Guitar & Instrument Wireless Systems product category.
