Audio-Technica PRO 49Q Cardioid Condenser Gooseneck Mic
Brand:|Model: PRO 49Q|Part # 242-4868
The PRO 49Q quick-mount double-gooseneck cardioid condenser microphone is designed to plug into any standard XLRF-type surface or cable connector.
ORDER TODAY
Ships in 5-7 business days
$119.00
Part # 242-4868
  • Wide-range condenser element with low-mass diaphragm for superior performance
  • Self-contained electronics eliminate need for external power modules
  • Flat, smooth frequency response
  • Quiet, fixed-placement long-life gooseneck
  • Plugs into any standard XLRF-type surface or cable connector
  • Overall length of 13.07" (332.0 mm)
Frequently Bought Together
The PRO 49Q quick-mount double-gooseneck cardioid condenser microphone is designed to plug into any standard XLRF-type surface or cable connector. With a flat, smooth frequency response and self-contained electronics, this mic features a quiet, fixed-placement, long-life gooseneck and wide-range condenser element with low-mass diaphragm for superior performance.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 70-16,000 Hz • Open circuit sensitivity: -37 dB (14.1 mV) re 1V at 1 Pa • Impedance: 100 ohms • Maximum input sound level: 134 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 106 dB, 1 kHz at Max SPL • S/N ratio: 66 dB, 1 kHz at 1 Pa • Phantom power requirements: 9-52V DC, 2 mA typical • Dimensions: 13.07" (332.0 mm) long, 0.47" (12.0 mm) head diameter, 0.74" (18.9 mm) base diameter • Output connector: Integral 3-pin XLRM-type • Accessories furnished: AT8146 windscreen • Audio-Technica case style: M23.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelPRO 49Q
  • Part Number242-4868
  • UPC042005308545
  • Product CategoryGooseneck / Podium Microphones
  • Weight0.45 lbs.
View similar products to the Audio-Technica PRO 49Q Cardioid Condenser Gooseneck Mic
in the Gooseneck / Podium Microphones product category.
