Audio-Technica PRO 35 Cardioid Condenser Clip-On Microphone
Brand:|Model: PRO35|Part # 242-4854
Designed for sax, toms, brass and percussion, the PRO 35 excels in high-SPL applications and is ideal for active stage performances.
ORDER TODAY
Ships in 5-7 business days
$149.00
Part # 242-4854
Designed for sax, toms, brass and percussion, the PRO 35 excels in high-SPL applications and is ideal for active stage performances. Its extended frequency response captures subtle nuances of the performance. The included UniMount® clip permits accurate positioning and provides shock resistance while protecting the element. The microphone's cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of the desired sound source. Includes AT8418 UniMount®instrument mount, AT8538 power module, and a soft protective pouch.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 50-15,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: -45 dB (5.6 mV) re 1V at 1 Pa • Impedance: 250 ohms • Maximum input sound level: 145 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 115 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 64 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Switch: Flat, roll-off • Dimensions: Microphone 0.98" (25.0 mm) long, 0.40" (10.2 mm) diameter; Power module 3.66" (92.9 mm) long, 0.74" (18.9 mm) diameter • Output connector: Power module, Integral 3-pin XLRM-type • Cable: 6 ft. (1.8 m) long (permanently attached to microphone), 0.10" (2.6 mm) diameter, 2-conductor, shielded cable with TA3F-type connector.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelPRO35
  • Part Number242-4854
  • UPC042005141104
  • Product CategoryInstrument Microphones
  • Weight0.65 lbs.
View similar products to the Audio-Technica PRO 35 Cardioid Condenser Clip-On Microphone
in the Instrument Microphones product category.
