Audio-Technica PRO-301/H-T2 Pro Series 3 VHF Wireless Headworn Microphone System
Brand:|Model: PRO-301/H-T2|Part # 242-5160
Pro Series 3 Wireless Systems are designed with you in mind. Standard features include quick and easy set up, simplicity of use, durable construction for long life, and of course, the crystal clear sound quality upon which Audio-Technica has built their formidable reputation.
  • Reliable performance and durable construction
  • Easy operation and clear, natural sound quality
  • Hi-ENERGY® neodymium element for crisp sound reproduction
  • Low-visibility headband provides stable, comfortable fit
  • Available in 3 different frequencies
Frequently Bought Together
Audio Technica's Pro Series 3 systems provide reliable rock-solid performance, simple operation, and exceptional sound quality. Available in handheld, headworn, guitar/instrument, lavalier and bodypack-only configurations, the Pro Series 3 Wireless Systems are single-channel, fixed-frequency systems available in three VHF travelling frequencies (169.505, 170.245, and 171.905 MHz; designated T2, T3, and T8, respectively) that operate outside the range of US broadcast television. All three fixed-frequency systems work together with no interference from TV channels, and no frequency coordination is required.
Each Pro Series 3 Wireless System includes a PRO-R300 receiver. The PRO-R300 is a non-diversity, single-channel receiver with advanced dipole antenna design for extended operating range, which improves operation by providing a ground element in addition to the usual signal element. The PRO-R300 also offers volume control along with AF Peak, RF and Power indicator lights. The PRO-301/H-T2 includes the UniPak® transmitter with variable trim adjustment, on/off/standby switch, and pro-grade 4-pin locking connector for the included PRO 8HEcW hypercardioid dynamic headset microphone, offering professional quality vocal reproduction in a hands-free form factor. The flexible boom can be configured to rest on the right or left side of the user's head, and offers nearly unlimited adjustability to accommodate virtually any speaker or vocalist's needs and comfort. All components fit conveniently in an included rugged case, ideal for storage and life on the road.
Overall System Specifications: • Operating frequency: VHF high band, 169 to 172 MHz • Frequency stability: ± 0.005% • Modulation mode: FM • 200 feet (60m) typical (open range line-of-sight environment with no interfering signals) • Operating temperature range: 40° to 110° F (4° to 43° C) Note: battery performance may be affected at very low temperatures.
Receiver Specifications: • Receiving system: Non-diversity, single channel, dual antenna • Image rejection: 50 dB minimum • S/N ratio: 80 dB @ 10 kHz deviation (IEC-weighted), maximum modulation 15 kHz • Audio output: 1/4" unbalanced • Power supply (included): 100-240 VAC 50/60 Hz • Dimensions: 7.48" W x 1.65" H x 5.12" D (190 x 42 x 130 mm) • Weight: 11 oz. (311 g).
UniPak® Transmitter Specifications: • RF power output: 10mW (high); 2mW (low), typical • Input connector: 4-pin locking (pin 1 - GND; pin 2 - instrument input; pin 3 - microphone input; pin 4 - DC bias +9V) • Battery: 9V alkaline (not included) • Battery life: 15 hours (high); 20 hours (low) typical (depending on battery type and usage pattern) • Dimensions: 2.56" W x 4.33" H x 1.00" D (65 x 110 x 25.4 mm) • Weight: 2.8 oz. (78 g) without batteries.
PRO 8HEcW Specifications:  Element: Neodymium dynamic • Polar pattern: Hypercardioid • Frequency response: 200-18,000 Hz • Open circuit sensitivity: -55 dB (1.7 mV) re 1V at 1 Pa • Impedance: 600 ohms • Weight: 2.1 oz (60 g) • Accessories furnished: AT8139L large windscreen, AT8139S small windscreen and AT8439 clothing clip
  • Frequency BandVHF
  • BrandAudio-Technica
  • ModelPRO-301/H-T2
  • Part Number242-5160
  • UPC042005176250
  • Product CategoryHeadworn / Headset Wireless Systems
  • Weight4.35 lbs.
View similar products to the Audio-Technica PRO-301/H-T2 Pro Series 3 VHF Wireless Headworn Microphone System
in the Headworn / Headset Wireless Systems product category.
