Audio-Technica PRO-301/G-T3 Pro Series 3 VHF Wireless Guitar & Instrument System
Brand:|Model: PRO-301/G-T3|Part # 242-5144
Pro Series 3 Wireless Systems are designed with you in mind. Standard features include quick and easy set up, simplicity of use, durable construction for long life, and of course, the crystal clear sound quality upon which Audio-Technica has built their formidable reputation.
  • Reliable performance and durable construction
  • Easy operation and clear, natural sound quality
  • Includes 1/4" instrument cable
  • Available in 3 different frequencies
Frequently Bought Together
Audio Technica's Pro Series 3 systems provide reliable rock-solid performance, simple operation, and exceptional sound quality. Available in handheld, headworn, guitar/instrument, lavalier and bodypack-only configurations, the Pro Series 3 Wireless Systems are single-channel, fixed-frequency systems available in three VHF travelling frequencies (169.505, 170.245, and 171.905 MHz; designated T2, T3, and T8, respectively) that operate outside the range of US broadcast television. All three fixed-frequency systems work together with no interference from TV channels, and no frequency coordination is required.
Each Pro Series 3 Wireless System includes a PRO-R300 receiver. The PRO-R300 is a non-diversity, single-channel receiver with advanced dipole antenna design for extended operating range, which improves operation by providing a ground element in addition to the usual signal element. The PRO-R300 also offers volume control along with AF Peak, RF and Power indicator lights. The PRO-301/G-T3 includes the UniPak® transmitter with variable trim adjustment, on/off/standby switch, and pro-grade 4-pin locking connector for the included 1/4" high impedance instrument cable. All components fit conveniently in an included rugged case, ideal for storage and life on the road.
Overall System Specifications: • Operating frequency: VHF high band, 169 to 172 MHz • Frequency stability: ± 0.005% • Modulation mode: FM • 200 feet (60m) typical (open range line-of-sight environment with no interfering signals) • Operating temperature range: 40° to 110° F (4° to 43° C) Note: battery performance may be affected at very low temperatures.
Receiver Specifications: • Receiving system: Non-diversity, single channel, dual antenna • Image rejection: 50 dB minimum • S/N ratio: 80 dB @ 10 kHz deviation (IEC-weighted), maximum modulation 15 kHz • Audio output: 1/4" unbalanced • Power supply (included): 100-240 VAC 50/60 Hz • Dimensions: 7.48" W x 1.65" H x 5.12" D (190 x 42 x 130 mm) • Weight: 11 oz. (311 g).
UniPak® Transmitter Specifications: • RF power output: 10mW (high); 2mW (low), typical • Input connector: 4-pin locking (pin 1 - GND; pin 2 - instrument input; pin 3 - microphone input; pin 4 - DC bias +9V) • Battery: 9V alkaline (not included) • Battery life: 15 hours (high); 20 hours (low) typical (depending on battery type and usage pattern) • Dimensions: 2.56" W x 4.33" H x 1.00" D (65 x 110 x 25.4 mm) • Weight: 2.8 oz. (78 g) without batteries.
  • Frequency BandVHF
  • BrandAudio-Technica
  • ModelPRO-301/G-T3
  • Part Number242-5144
  • UPC042005176571
  • Product CategoryGuitar & Instrument Wireless Systems
  • Weight4.35 lbs.
View similar products to the Audio-Technica PRO-301/G-T3 Pro Series 3 VHF Wireless Guitar & Instrument System
in the Guitar & Instrument Wireless Systems product category.
