Audio-Technica MT830R Sub-Mini Omnidirectional Condenser Mic
Brand:|Model: MT830R|Part # 242-4842
Designed to be worn as a lavalier or hidden in loose clothing or in the hair, the MT830R provides high intelligibility for lecturers, stage/TV performers and singers. It operates on phantom power only.
ORDER TODAY
Ships in 5-7 business days
$189.00
Part # 242-4842
  • Small size provides excellent yet unobtrusive sound pickup
  • High intelligibility for lecturers, stage/TV performers and singers
  • Wide-range capability ensures clean, accurate reproduction
  • 25' (7.6 m) cable permanently attached to mic, TA3F connector at power module
Designed to be worn as a lavalier or hidden in loose clothing or in the hair, the MT830R provides high intelligibility for lecturers, stage/TV performers and singers. The mic's wide-range capability ensures clean, accurate reproduction. It operates on phantom power only.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Omnidirectional • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –37 dB (14.1 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 135 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 108 dB, 1 kHz at Max SPL • S/N ratio: 67 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Switch: Flat, roll-off • Dimensions: Microphone 15.8 mm (0.62") long, 8.3 mm (0.33") wide, 5.0 mm (0.19") thick; Power module 92.9 mm (3.66") long, 18.9 mm (0.74") diameter • Output connector: Integral 3-pin XLRM-type • Cable: 7.6 m (25 ft.) long (permanently attached to microphone), 2.5 mm (0.10") diameter, 2-conductor, shielded cable with TA3F-type output connector • Accessories furnished: AT8538 power module, clothing clip and windscreens • Audio-Technica case style: M7.
  • BrandAudio-Technica
  • ModelMT830R
  • Part Number242-4842
  • UPC042005308453
  • Product CategoryLavalier Microphones
  • Weight0.58 lbs.
View similar products to the Audio-Technica MT830R Sub-Mini Omnidirectional Condenser Mic
in the Lavalier Microphones product category.
