Audio-Technica MT830cT5-TH Omnidirectional Lavalier Mic
Brand:|Model: MT830cT5-TH|Part # 242-4836
Designed to be worn as a lavalier or hidden in loose clothing or in the hair, the MT830cT5-TH (beige) provides high intelligibility for lecturers, stage/TV performers and singers. 55" shielded cable terminated with TA5F-type output connector for ATW-U101 and Lectrosonics transmitters.
  • Small size provides excellent yet unobtrusive sound pickup
  • High intelligibility for lecturers, stage/TV performers and singers
  • Wide-range capability ensures clean, accurate reproduction
Designed to be worn as a lavalier or hidden in loose clothing or in the hair, the MT830cT5-TH (beige) provides high intelligibility for lecturers, stage/TV performers and singers. The mic's wide-range capability ensures clean, accurate reproduction. 55" shielded cable terminated with TA5F-type output connector for ATW-U101 and Lectrosonics transmitters. Includes windscreens and clothing clip.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Omnidirectional • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 18 dB/octave • Open circuit sensitivity: –37 dB (14.1 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 135 dB SPL, 1 kHz at 1% THD • Dynamic Range (typical): 108 dB, 1 kHz at Max SPL • S/N Ratio: 67 dB, 1 kHz at 1 Pa • Dimensions: Microphone 15.8 mm (0.62") long, 8.3 mm (0.33") wide, 5.0 mm (0.19") thick • Output connector: Integral 3-pin XLRM-type • Cable: 55" cable terminated with TA5F-type output connector for ATW-U101 and Lectrosonics transmitters • Accessories furnished: Clothing clip and windscreens • Audio-Technica case style: M7.
  • BrandAudio-Technica
  • ModelMT830cT5-TH
  • Part Number242-4836
  • UPC042005308651
  • Product CategoryMicrophones & Cables for Wireless Bodypack
  • Weight0.32 lbs.
View similar products to the Audio-Technica MT830cT5-TH Omnidirectional Lavalier Mic
in the Microphones & Cables for Wireless Bodypack product category.
