242-4816_ALT_0
242-4816_ALT_1
Audio-Technica MB 1k Handheld Unidirectional Vocal Mic
Brand:|Model: MB 1K|Part # 242-4816
A perfect introductory performance mic, the high-output MB 1k is designed for use as a lead, backup, or choral vocal microphone.
Part # 242-4816
  • High-output design for vocals that cut through the mix
  • Unidirectional dynamic element design
  • Rugged all-metal construction
  • Hi-ENERGY® neodymium magnet for improved output and transient response
  • Reduced handling noise thanks to anti-shock engineering
  • Silent on-off operation thanks to MagnaLock™ switch design
  • Corrosion-resistant gold-plated XLRM-type connector
A perfect introductory performance mic, the high-output MB 1k is designed for use as a lead, backup, or choral vocal microphone. It features Audio-Technica’s Hi-ENERGY® neodymium magnet structure for maximum output and fast transient response, lockable MagnaLock™ switch design for silent on/off operation, and a corrosion-resistant gold-plated XLRM-type connector.
Specifications: • Element: Neodymium dynamic • Polar pattern: Unidirectional • Frequency response: 80-12,000 Hz • Open circuit sensitivity: -53 dB (2.2 mV) re 1V at 1 Pa • Impedance: 600 ohms • Switch: MagnaLock™ on/off • Dimensions: 7.27" (184.7 mm) long, 2.19" (55.6 mm) head diameter • Output connector: Integral 3-pin gold-plated XLRM-type • Accessories furnished: AT8470 Quiet-Flex™ stand clamp for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter • Audio-Technica case style: T1.
  • Element TypeDynamic
  • Polar PatternCardioid
  • On/Off SwitchYes
  • BrandAudio-Technica
  • ModelMB 1K
  • Part Number242-4816
  • UPC042005132553
  • Product CategoryVocal Microphones
  • Weight1.3 lbs.
View similar products to the Audio-Technica MB 1k Handheld Unidirectional Vocal Mic
in the Vocal Microphones product category.
