Audio-Technica M3M Wireless In-Ear Monitor System Freq M
Brand:|Model: M3M|Part # 242-4806
Audio-Technica's advanced M3 IEM system offers a full range of professional in-ear monitoring features, with a choice of 1321 UHF channels and easy-to-read LCD information displays on both transmitter and receiver. Operates on frequency M 614.000 to 647.000 MHz, 1321 frequencies (TV 38-43).
ORDER TODAY
Ships in 5-7 business days
$799.00
Part # 242-4806
  • High-fidelity sound with an articulate mix allows hearing at lower volumes
  • 1321 selectable UHF channels with automatic frequency scanning
  • Up to 16 simultaneous systems per frequency band
  • Three receiver modes: Personal Mix, stereo, and mono
  • Personal Mix Control allows volume and mix control of two independent signals at the receiver
  • LCD information display offers step-through menus for setting preferences
  • Adjustable squelch eliminates annoying static
Audio-Technica's advanced M3 IEM system offers a full range of professional in-ear monitoring features, with a choice of 1321 UHF channels and easy-to-read LCD information displays on both transmitter and receiver for setting preferences. The stereo monitor system is equipped with Audio-Technica's versatile Personal Mix Control, which allows volume and mix control of two independent signals on stage, via controls on the M3R stereo body-pack receiver. While up to 16 complete M3 systems may be used simultaneously, the M3R stereo receiver can operate on the same frequency with a single M3T stereo transmitter. The M3T Stereo Transmitter is equipped with two XLR / 1/4" combo input connectors into which users can connect line-level inputs (from a mixing console, for example). The M3T also offers a headphone output that allows you to monitor transmitter input signals directly. Selectable auxiliary input offers connection point for ambient microphone, click track, or other mic- or line-level input. System includes M3T stereo transmitter, M3R stereo receiver, and EP3 in-ear dynamic headphones. Operates on frequency M 614.000 to 647.000 MHz, 1321 frequencies (TV 38-43).
Overall System
Specifications: • Operating frequencies: Band M 614.000 to 647.000 MHz, 1321 frequencies (TV 38-43) • Minimum frequency step: 25 kHz • Modulation mode: FM stereo • Maximum deviation: ±40 kHz • Dynamic range: 90 dB (typical), A-weighted • Total harmonic distortion: <1% at (1 kHz, ±20 kHz Deviation) • Operating range: 100 m (300 ft.), typical (Open range environment with no interfering signals) • Operating temperature range: -5° C (23° F) to +50° C (122° F) (Battery performance may be reduced at very low temperatures.) • Frequency response: 60 Hz to 13 kHz (+/-3 dB).
Receiver
Specifications: • Receiving system: Double conversion superheterodyne • RF sensitivity: 20 dBuV (at 60 dB S/N ratio, 50 ohms termination) • Headphone output connector: 3.5 mm TRS stereo phone jack • Headphone output power: 65 mW (at 32 ohms) • Antenna input: SMA-type, 50 ohms • Aux Iinput connector: 3.5 mm TRS stereo phone jack • Batteries: 2 x 1.5V AA (not included) • Battery life: 8 hours (alkaline), depending on battery type and use pattern • Dimensions: 2.76" W x 0.98" D x 4.33" H (70 x 25 x 110 mm) • Weight: 133 g (4.7 oz.), without batteries • Accessories included: EP3 earphone and flexible antenna.
Transmitter
Specifications: • RF Power output: 10mW/50 mW (switchable internally), 50 ohms, limited to 10 mW within 863 MHz to 865 MHz • Input connectors: XLRF-type/6.3 mm stereo (1/4") combination connector • Maximum input level: XLRF-type/6.3 mm stereo, (1/4") balanced: +26 dB 6.3 mm (1/4") mono, unbalanced: +26 dBu • Loop output connector: XLRM-type connector • Power requirement: 12-18 VDC, 600 mA • Dimensions: 8.30" W x 5.20" D x 1.70" H (210 x 132 x 44 mm) • Weight: 32.8 oz. (930 g), without accessories • Accessories included: AC adapter (country dependent), and rack mount adapters.
  • BrandAudio-Technica
  • ModelM3M
  • Part Number242-4806
  • UPC4961310100568
  • Product CategoryPersonal Monitor Systems
  • Weight5.5 lbs.
View similar products to the Audio-Technica M3M Wireless In-Ear Monitor System Freq M
in the Personal Monitor Systems product category.
