Audio-Technica M2L Wireless In-Ear Monitor System
Brand:|Model: M2L|Part # 242-4796
The M2 wireless in-ear monitor system is designed to make professional in-ear monitoring features accessible for performers who want to be free from the problems associated with floor wedges. Operates on frequency L 575.000 to 608.000 MHz, 100 frequencies (TV 31-36).
ORDER TODAY
Ships in 5-7 business days
List Price$899.00
You Save33%
$599.00
Part # 242-4796
  • High-fidelity sound with clean, articulate mix allows you to hear yourself better at lower volume
  • 100 selectable UHF channels
  • Up to 10 simultaneous systems per frequency band
  • Three receiver modes: Personal Mix, stereo, and mono
  • Personal Mix Control allows volume and mix control of two independent signals at the receiver
  • 3.5 mm line-in jack connects to ambient microphone, click track & more
  • LED indicators provide easy-to-read level monitoring
The M2 wireless in-ear monitor system is designed to make professional in-ear monitoring features accessible for performers who want to be free from the problems associated with floor wedges. The stereo monitor system offers Personal Mix Control, which gives each musician volume and mix control of two independent signals on stage, via easy-to-use controls on the M2R stereo body-pack receiver. The wireless UHF M2T Stereo Transmitter provides a choice of 100 selectable frequencies and is equipped with two XLR/1/4" combo input connectors into which users can connect line-level inputs. While up to 10 complete M2 systems may be used on stage simultaneously, any number of M2R stereo receivers may be used on the same frequency with a single M2T stereo transmitter. These rugged systems are built to stand up to the inevitable bumps of life on the road, delivering clear, natural sound for touring and installed-sound uses. Operates on Band L 575.000 to 608.000 MHz, 100 frequencies (TV 31-36).
Overall System
Specifications: • Operating frequencies: Band L 575.000 to 608.000 MHz, 100 frequencies (TV 31-36) • Minimum frequency step: 25 kHz • Modulation mode: FM stereo • Maximum deviation: ±40 kHz • Dynamic range: 90 dB (typical), A-weighted • Total harmonic distortion: <1% at (1 kHz, ±20 kHz Deviation) • Operating range: 100 m (300 ft.), typical • Open range environment with no interfering signals • Operating temperature range: -5° C (23° F) to +50° C (122° F) • Battery performance may be reduced at very low temperatures • Frequency response: 60 Hz to 13 kHz (+/- 3 dB).
Receiver
Specifications: • Receiving system: Double conversion superheterodyne • RF sensitivity: 20 dBuV (at 60 dB S/N ratio, 50 ohms termination) • Headphone output connector: 3.5 mm TRS stereo phone jack • Headphone output power: 65 mW (at 32 ohms) • Antenna input: SMA-type, 50 ohms • Aux input connector: 3.5 mm TRS stereo phone jack • Batteries: 2 x 1.5V AA (not included) • Battery life: 8 hours (alkaline) *depending on battery type and use pattern • Dimensions: 2.76" W x 0.98" D x 4.33" H (70 x 25 x 110 mm) • Weight: 110 g (3.9 oz.), without batteries • Accessories included: EP3 earphone, frequency slicker, and flexible antenna.
Transmitter
Specifications: • RF Power output: 10mW/30 mW (switchable internally), 50 ohms, limited to 10 mW within 863 MHz to 865 MHz • Input connectors: XLRF-type/6.3 mm stereo (1/4") combination connector • Maximum input level: XLRF-type/6.3 mm stereo, (1/4") balanced: +26 dB 6.3 mm (1/4") mono, unbalanced: +26 dBu • Loop output connector: XLRM-type connector • Power requirement: 12-18 VDC, 600 mA • Dimensions: 8.30" W x 5.20" D x 1.70" H (210 x 132 x 44 mm) • Weight: 30.7 oz. (870 g), without accessories • Accessories included: AC adapter (country dependent), and rack mount adapters.
  • BrandAudio-Technica
  • ModelM2L
  • Part Number242-4796
  • UPC4961310100506
  • Product CategoryPersonal Monitor Systems
  • Weight4.5 lbs.
View similar products to the Audio-Technica M2L Wireless In-Ear Monitor System
in the Personal Monitor Systems product category.
