Audio-Technica BP4029 Stereo Shotgun 9.3" Microphone
Brand:|Model: BP4029|Part # 242-4774
The BP4029 (9.29" long) stereo shotgun is engineered for high-end broadcast and production use. Microphone features independent line-cardioid and figure-of-eight elements configured in an MS (Mid-Side) arrangement with switch-selectable internal matrixing.
ORDER TODAY
Ships in 5-7 business days
$749.00
Part # 242-4774
  • Designed for broadcasters, videographers and sound recordists
  • Compact, lightweight design is perfect for camera-mount use
  • Independent Line-cardioid and Figure-of-eight condenser elements
  • Switchable low-frequency roll-off
  • Switch selection of non-matrixed M-S mode and two internally-matrixed left/right stereo modes
  • Includes a 0.61 m (24") cable (5-pin XLRF to two standard 3-pin XLRM connectors)
  • RoHS compliant—free from all substances specified in the EU directive on hazardous substances
Based on models originally developed for use in the broadcast of the Sydney Games in 2000, the BP4029 (9.29" long) stereo shotgun is engineered for high-end broadcast and production use. Microphone features independent line-cardioid and figure-of-eight elements configured in an MS (Mid-Side) arrangement with switch-selectable internal matrixing. This innovative microphone allows sound recordists the choice of selecting a left-right stereo output (wide or narrow) via the microphone’s internal matrixing system or choosing discrete Mid-Side signals for later manipulation, a flexibility not available from any other manufacturer. A switchable low frequency roll-off filter helps minimize the pickup of unwanted low frequency noise. These phantom-powered models feature a rugged lightweight design and sleek black color scheme, perfect for on-camera use.
Specifications: • Elements: Fixed-charge back plate, permanently polarized condenser • Polar patterns: Line-cardioid, Figure-of-eight • Frequency response: 40-20,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: Mid -30 dB (31.6 mV) re 1V at 1 Pa; Side -34 dB (19.9 mV) re 1V at 1 Pa; LR stereo -36 dB (15.8 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: Mid 123 dB SPL, 1 kHz at 1% THD; Side 127 dB SPL, 1 kHz at 1% THD; LR stereo 126 dB SPL, 1 kHz at 1% THD • Dynamic range: (typical): Mid 101 dB, 1 kHz at max SPL; Side 101 dB, 1 kHz at max SPL; LR stereo 102 dB, 1 kHz at max SPL • S/N ratio: Mid 72 dB SPL, 1 kHz at 1 Pa; Side 68 dB SPL, 1 kHz at 1 Pa; LR Stereo 70 dB SPL, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 4 mA typical at 48V, each channel • Switches: M-S, LR stereo-wide (LR-W), LR stereo-narrow (LR-N); Flat, roll-off • Dimensions: 9.29" (236.0 mm) long, 0.83" (21.0 mm) diameter • Output connector: Integral XLR5M-type • Cable: Dual 24" (0.61 m) shielded two-conductor, terminated in two XLR3M-type connectors • Accessories furnished: AT8405a stand clamp for 5/8"-27 threaded stands, AT8134 foam windscreen, 5/8"-27 to 3/8"-16 threaded adapter, and a protective carrying case • Audio-Technica case style: SG2.
  • BrandAudio-Technica
  • ModelBP4029
  • Part Number242-4774
  • UPC4961310098308
  • Product CategoryShotgun / Camera Microphones
  • Weight1.85 lbs.
View similar products to the Audio-Technica BP4029 Stereo Shotgun 9.3" Microphone
in the Shotgun / Camera Microphones product category.
