Audio-Technica ATW-801-T3 System 8 VHF Wireless UniPak System
Brand:|Model: ATW-801-T3|Part # 242-5102
System 8 Wireless Systems are designed with you in mind. Standard features include quick and easy set up, simplicity of use, durable construction for long life, and of course, the crystal clear sound quality upon which Audio-Technica has built their formidable reputation.
ORDER TODAY
Ships in 5-7 business days
List Price$149.95
You Save43%
$84.95
Part # 242-5102
  • Reliable performance and durable construction
  • Easy operation and clear, natural sound quality
  • Professional locking 4-pin connector
  • Available in 3 different frequencies
Audio-Technica's System 8 VHF Wireless Systems are engineered for today's demanding professional. Featuring sleek contemporary styling and stackable housings, the System 8 Wireless Systems are designed to provide years of reliable performance, easy setup, and only the cleanest, most natural sound quality. The ATW-801-T3 is a single-channel, fixed-frequency bodypack system, operating in the 170.245 MHz range (also available in 169.505 and 171.905 MHz, designated T2 and T8, respectively). You get the ATW-R800 receiver with 1/4" output, dipole antennae for extended range, as well as Power, RF, and Peak indicators and user-adjustable squelch. You also get the ATW-T801 UniPak® transmitter, which features variable trim control, multi-color power/battery indicator, pro-grade locking 4-pin connector, and operates on standard AA batteries to make it through long shows or presentations with ease. Add the headset or lavalier microphone of your choice (or the AT-GcW instrument cable), and you'll be rocking the casbah in no time!
Overall System Specifications: • Operating Frequency: VHF highband, 169 to 172 MHz • Modulation mode: FM • Frequency response: 80 - 13,000 Hz • Dynamic range >/= 90 dB (A-weighted), typical • THD: <1% (@ 1 kHz) • Operating range: 200 feet (60m) typical (open range line-of-sight environment with no interfering signals) • Operating temperature range: 40° to 110° F (4° to 43° C) Note: battery performance may be affected at very low temperatures.
Receiver Specifications: Receiving system: Non-diversity, single channel, dual antenna • Image rejection: 50 dB minimum • RF sensitivity: 20 dBuV @ 60 dB S/N ratio (50 ohm termination) • Audio output: 1/4" unbalanced • Power supply (included): 100-240 VAC 50/60 Hz • Dimensions: 7.46" W x 1.82" H x 5.06" D (190 x 46.2 x 128.5 mm) • Weight: 11.8 oz. (335 g).
Transmitter Specifications: RF power output: 10mW • Input connector: 4-pin locking (pin 1 - GND; pin 2 - instrument input; pin 3 - microphone input; pin 4 - DC bias +9V) • Batteries: 2 AA alkaline (not included) • Battery life: 8 hours typical (depending on battery type and usage pattern) • Dimensions: 2.76" W x 4.08" H x 0.98" D (70.2 x 103.7 x 24.9 mm) • Weight: 3 oz. (84.5 g) without batteries.
  • Frequency BandVHF
  • BrandAudio-Technica
  • ModelATW-801-T3
  • Part Number242-5102
  • UPC4961310116255
  • Product CategoryBodypack-Only Wireless Systems
  • Weight2.6 lbs.
View similar products to the Audio-Technica ATW-801-T3 System 8 VHF Wireless UniPak System
in the Bodypack-Only Wireless Systems product category.
