242-4574_ALT_0
Audio-Technica ATM710 Cardioid Condenser Handheld Mic
Brand:| Model: ATM710
The new Artist Series vocal condenser microphone is tailored for exacting detail and high-fidelity vocal reproduction. The ATM710 is also equipped with a switchable 10 dB pad that lowers the microphone's sensitivity, providing higher SPL capability.
  • Excels in venues with controlled stage volume or in-ear monitoring
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • Superior anti-shock engineering for low handling noise
  • Multi-stage grille design offers excellent protection against plosives and sibilance
  • Condenser design for studio-quality performance
  • Integral 80 Hz HPF switch and 10 dB pad
  • Corrosion-resistant contacts from gold-plated XLRM-type connector
242-4574
Weight: 1.25 lbs.
IN STOCK
Order Soon - Only 1 Left In Stock
List Price$349.00
You Save43%
$199.00
Part # 242-4574
The new Artist Series vocal condenser microphone is tailored for exacting detail and high-fidelity vocal reproduction. With a condenser design for studio-quality performance, the ATM710 delivers remarkable clarity. The microphone is equipped with an integral 80 Hz hi-pass filter that provides easy switching from a flat frequency response to a low-end roll-off position that reduces the microphone's sensitivity to popping in close vocal use. The ATM710 is also equipped with a switchable 10 dB pad that lowers the microphone's sensitivity, providing higher SPL capability. The microphone's cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of the desired sound source.
Specifications: • Element: Fixed-charge back plate permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 40-20,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: –40 dB (10.0 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 148 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 127 dB, 1 kHz at Max SPL • S/N ratio: 73 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 3.5 mA typical • Switches: Flat, roll-off; 10 dB pad • Dimensions: 179.0 mm (7.05") long, 50.0 mm (1.97") diameter • Output connector: Integral 3-pin XLRM-type • Accessories furnished: AT8470 Quiet-Flex™ stand clamp for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter; soft protective pouch • Audio-Technica Case Style: T6.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelATM710
  • Part Number242-4574
  • UPC4961310089054
  • Product CategoryVocal Handheld Microphones
  • Weight1.25 lbs.
View similar products to the Audio-Technica ATM710 Cardioid Condenser Handheld Mic
in the Vocal Handheld Microphones product category.
Customer projects that include: Audio-Technica ATM710 Cardioid Condenser Handheld Mic
