Audio-Technica ATM350 Cardioid Condenser Clip-On Microphone
Brand:|Model: ATM350|Part # 242-4562
Supplied with Audio-Technica's versatile UniMount® clip and new violin mount, the low-profile ATM350 is an exceptional cardioid condenser microphone designed to clip to brass, upright bass, reeds, piano, snare, toms, and violin. Features an integral 80 Hz hi-pass filter on the in-line power module.
ORDER TODAY
Ships in 5-7 business days
List Price$489.00
You Save43%
$279.00
Part # 242-4562
  • Low-profile design for minimum visibility
  • UniMount® clip permits accurate positioning, provides shock resistance and protects element
  • Unique violin mount permits unobtrusive placement of microphone
  • Crisp, clear, well-balanced response, even at high SPLs
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • Interchangeable elements available for hypercardioid and omnidirectional polar patterns
  • Corrosion-resistant contacts from gold-plated XLRM-type connector
Supplied with Audio-Technica's versatile UniMount® clip and new violin mount, the low-profile ATM350 is an exceptional cardioid condenser microphone designed to clip to brass, upright bass, reeds, piano, snare, toms, and violin. The microphone offers a crisp, clear, well-balanced response, even at high SPLs. It features an integral 80 Hz hi-pass filter on the in-line power module. Its cardioid polar pattern reduces pickup of sounds from the side and rear for effective protection against feedback. Included furnished accessories: AT8542 power module, AT8418 UniMount® microphone instrument mount, AT8468 violin mount, and a soft protective pouch.
Specifications: • Element: Fixed-charge back plate permanently polarized condenser • Type: Cardioid • Frequency response: 40-20,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: 49 dB (3.5 mV) re 1V at 1 Pa • Impedance: 50 ohms • Maximum input sound level: 149 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): 122 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 67 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 3.5 mA typical • Switch: Flat, roll-off • Dimensions: Microphone 37.8 mm (1.49") long, 12.2 mm (0.48") diameter; Power module 92.9 mm (3.66") long, 18.9 mm (0.74") diameter • Output connector: Power module integral 3-pin XLRM-type • Cable: 4.0 m (13.1 ft.) long (permanently attached to microphone), 3.2 mm (0.13") diameter, 2-conductor shielded cable with TA3F-type connector.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelATM350
  • Part Number242-4562
  • UPC4961310089009
  • Product CategoryInstrument Microphones
    (2 Reviews)
  • Weight0.9 lbs.
View similar products to the Audio-Technica ATM350 Cardioid Condenser Clip-On Microphone
in the Instrument Microphones product category.
