242-4560_ALT_0
242-4560_ALT_1
Audio-Technica ATM250DE Dual Element Instrument Mic
Brand:| Model: ATM250DE
The ATM250DE dual-element instrument microphone features cardioid condenser and hypercardioid dynamic capsules combined in a single housing. The elements are positioned in a perfect phase relationship, something practically impossible to achieve with two separate microphones.
  • Audio-Technica‚Äôs proven dual-element design features two elements enclosed in a single housing
  • Elements are positioned in a perfect phase relationship
  • Perfect for kick drum, guitar amps, percussion and other instruments
  • Integral 80 Hz HPF switch and 10 dB pad (condenser element)
  • Versatile mounting options and effective dampening of mechanical noise w/AT8471 isolation clamp
  • Corrosion-resistant contacts from gold-plated XLRM-type connector
  • Rugged, all-metal design and construction for years of trouble-free use
242-4560
Weight: 2.3 lbs.
ORDER TODAY
Ships in 5-7 business days
List Price$549.00
You Save45%
$299.00
Part # 242-4560
The ATM250DE dual-element instrument microphone features cardioid condenser and hypercardioid dynamic capsules combined in a single housing. Audio-Technica's innovative use of two polar patterns is ideal for kick drum: the hypercardioid dynamic element focuses tightly on the aggressive attack of the beater, while the condenser captures the round tonalities of the shell. The elements are positioned in a perfect phase relationship, something practically impossible to achieve with two separate microphones. Includes a professional isolation clamp to provide secure mounting, versatile positioning and effective dampening of unwanted mechanical noise.
Specifications: • Elements: Condenser, dynamic • Polar pattern: Cardioid (condenser), Hypercardioid (dynamic) • Frequency response: 40-20,000 Hz (condenser), 40-15,000 Hz (dynamic) • Low frequency roll-off: 80 Hz, 12 dB/octave (condenser) • Open circuit sensitivity: –49 dB (3.5 mV) re 1V at 1 Pa (condenser), –53 dB (2.2 mV) re 1V at 1 Pa (dynamic) • Impedance: 50 ohms (condenser), 600 ohms (dynamic) • Maximum input sound level: 148 dB SPL, 1 kHz at 1% T.H.D. (condenser) • Dynamic range (typical): 122 dB, 1 kHz at Max SPL (condenser) • S/N ratio: 68 dB, 1 kHz at 1 Pa (condenser) • Phantom power requirements: 11-52V DC, 3.5 mA typical (condenser) • Switches: Flat, roll-off; 10 dB pad (condenser only) • Dimensions: 143.6 mm (5.65") long, 55.0 mm (2.17") diameter • Output connector: Integral 5-pin XLRM-type • Cable: 5.0 m (16.5 ft.) dual shielded, 8-conductor cable, 5-pin XLRF-type connector at microphone, two 3-pin XLRM-type output connectors • Accessories furnished: AT8471 isolation clamp for 5/8"-27 threaded stands, 5/8"-27 to 3/8"-16 adapter, and a soft protective pouch • Audio-Technica case style: R9.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelATM250DE
  • Part Number242-4560
  • UPC4961310088996
  • Product CategoryInstrument Microphones
  • Weight2.3 lbs.
View similar products to the Audio-Technica ATM250DE Dual Element Instrument Mic
in the Instrument Microphones product category.
Customer projects that include: Audio-Technica ATM250DE Dual Element Instrument Mic
