Audio-Technica AT899c-TH Sub-Mini Omni Lavalier Mic
Brand:|Model: AT899c-TH|Part # 242-4496
Audio-Technica's omnidirectional AT899c-TH is engineered for intelligible, accurate voice reproduction. Features an unterminated 55" (1.4 m) cable.
Part # 242-4496
  • Maximum intelligibility & clean, accurate reproduction for vocalists, lecturers, stage & tv talent
  • Low-profile design (a mere 5 mm in diameter) is ideal for applications requiring minimum visibility
Audio-Technica's omnidirectional AT899c-TH is engineered for intelligible, accurate voice reproduction. Its low-profile design (a mere 5 mm in diameter) assures minimum visibility. The mic may be worn as a lavalier and is easily hidden in clothing or hair. Its switchable low-frequency roll-off reduces popping. Features an unterminated 55" (1.4 m) cable. Accessory kit included.
Specifications: • Element: Subminiature, fixed-charge back plate condenser • Polar pattern: Omnidirectional • Frequency response: 30-20,000 Hz • Open circuit sensitivity: Phantom -43 dBV, re 1V at 1 Pa • S/N ratio: 65 dB, 1 kHz at 1 Pa • Power requirements: Voltage range 1.1 - 12V; Current consumption 0.5 mA typical at 9V • Dimensions: 0.63" (16.1 mm) maximum length, 0.20" (5.0 mm) maximum body diameter • Cable: 55" (1.4 m) cable, unterminated • Audio-Technica Case Style: M29.
  • BrandAudio-Technica
  • ModelAT899c-TH
  • Part Number242-4496
  • UPC042005128587
  • Product CategoryLavalier Microphones
  • Weight0.4 lbs.
View similar products to the Audio-Technica AT899c-TH Sub-Mini Omni Lavalier Mic
in the Lavalier Microphones product category.
