Audio-Technica AT898 Sub-Mini Cardioid Lavalier Mic
Brand:|Model: AT898|Part # 242-4466
Designed to be worn as a lavalier or hidden in clothing, Audio-Technica’s discreet-design cardioid AT898 offers maximum intelligibility, accurate voice reproduction and unobtrusive appearance for use in houses of worship, broadcast studios, theaters, etc.
ORDER TODAY
Ships in 5-7 business days
$269.00
Part # 242-4466
  • Maximum intelligibility & clean accurate reproduction for lecturers, stage and television talent
  • Low-profile design (a mere 5 mm in diameter) is ideal for applications requiring minimum visibility
  • Operates on battery or phantom power
  • 9.8' (3.0 m) cable permanently attached to mic, TA3F connector at power module
  • RoHS compliant—free from all substances specified in the EU directive on hazardous substances
Designed to be worn as a lavalier or hidden in clothing, Audio-Technica’s discreet-design cardioid AT898 offers maximum intelligibility, accurate voice reproduction and unobtrusive appearance for use in houses of worship, broadcast studios, theaters, etc. Its switchable low-frequency roll-off reduces sensitivity to popping. Battery or phantom power.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 200-15,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: Phantom -43 dB (7.0 mV) re 1V at 1 Pa; Battery -46 dB (5.0 mV) re 1V at 1 Pa • Impedance: Phantom 200 ohms; Battery 250 ohms • Maximum input sound level: Phantom 131 dB SPL, 1 kHz at 1% THD; Battery 115 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): Phantom 100 dB, 1 kHz at Max SPL; Battery 84 dB, 1 kHz at Max SPL • S/N ratio: 63 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Battery type: 1.5V AA/UM3 • Battery Current: Life 0.4 mA / 1200 hours typical (alkaline) • Switch: Flat, roll-off (recessed) • Dimensions: Microphone 0.91" (23.0 mm) long, 0.21" (5.3 mm) diameter; Power module 5.71" (145.0 mm) long, 0.83" (21.0 mm) diameter • Output connector (power module): Integral 3-pin XLRM-type • Cable: 9.8 ft. (3.0 m) long (permanently attached to microphone), 0.08" (2 mm) dia., 2-conductor, shielded cable with TA3F output connector that mates with TB3M jack on power module • Accessories furnished: AT8537 power module, AT8439 cable clip, clothing clip base, viper clip base, magnet clip base and plate with lanyard, three single mic holders, two double mic holders, two windscreens, battery, and a protective carrying case • Audio-Technica case style: M30.
  • BrandAudio-Technica
  • ModelAT898
  • Part Number242-4466
  • UPC042005132744
  • Product CategoryLavalier Microphones
    (1 Reviews)
  • Weight1.05 lbs.
View similar products to the Audio-Technica AT898 Sub-Mini Cardioid Lavalier Mic
in the Lavalier Microphones product category.
