Audio-Technica AT8684 UniMix Microphone Attenuator
Brand:|Part # 242-4418
The AT8684 is a versatile attenuator that permits easy in-line switch installation and flexible application. Type of external single-pole switch the user supplies determines muting function; closed contact causes muting.
  • Professional XLR-type input/output connectors
  • Can be installed anywhere in-line, either at the mixer input or near the microphone
  • 24-48V DC phantom power and balanced cables required for operation
  • Permits phantom voltage to pass on to the microphone
  • Rugged steel housing
Frequently Bought Together
The AT8684 is a versatile attenuator that permits easy in-line switch installation and flexible application. Type of external single-pole switch the user supplies determines muting function; closed contact causes muting. Use for on/off, push-to-talk, push-to-mute, etc. (Additional, isolated poles on the switch may be used to control logic-level DC circuits.)
Specifications: • Input/output Cconnectors: XLRF/XLRM-type • Phantom power: 24-48V DC, 2-4 mA typical • Frequency response: 20-20,000 Hz • Gain: Unity (0 dB), +0/-1.5 dB • Noise (a-weighted): -115 dBV typical • Dimensions: 5.12" W x 2.36" D x 1.73" H typical (130.0 x 60.0 x 44.0 mm) • Input impedance: 5,300 ohms • Output impedance: 500 ohms • Maximum input level: +17 dBV (1% THD at 1 kHz) • Maximum attenuation: 57 dB at 1 kHz.
  • BrandAudio-Technica
  • Part Number242-4418
  • UPC042005310302
  • Product CategoryPhantom Power Supplies & Power Modules
  • Weight0.8 lbs.
View similar products to the Audio-Technica AT8684 UniMix Microphone Attenuator
in the Phantom Power Supplies & Power Modules product category.
