Audio-Technica AT8031 Cardioid Condenser Handheld Microphone
Brand:|Model: AT8031|Part # 242-4202
The AT8031 is ideal for close-up interviews, vocals, overheads, piano, and strings. Its cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of desired sound source.
ORDER TODAY
Ships in 5-7 business days
$179.00
Part # 242-4202
  • Ideal for close-up vocals, overheads, piano and strings
  • Low-mass diaphragm ensures minimum distortion
  • Cardioid pattern provides added warmth when used close up
  • Operates on battery or phantom power
  • RoHS compliant
Frequently Bought Together
The AT8031 is ideal for close-up interviews, vocals, overheads, piano, and strings. Its cardioid polar pattern reduces pickup of sounds from the sides and rear, improving isolation of desired sound source. The mics proximity effect provides added warmth when used close up. Features include a large protective screen that reduces "popping" and sibilant distortion. It operates on battery or phantom power.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 30-20,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: Phantom -44 dB (6.3 mV), re 1V at 1 Pa; Battery –45 dB (5.6 mV) re 1V at 1 Pa • Impedance: Phantom 250 ohms; Battery 300 ohms • Maximum input sound level: Phantom 137 dB SPL, 1 kHz at 1% THD; Battery 123 dB SPL, 1 kHz at 1% THD • Dynamic range (typical): Phantom 113 dB, 1 kHz at Max SPL; Battery 99 dB, 1 kHz at Max SPL • S/N ratio: 70 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 2 mA typical • Battery type: 1.5V AA/UM3 • Battery current/life: 0.4 mA / 1200 hours typical (alkaline) • Switch: Flat, roll-off • Dimensions: 7.60" long, 1.98" head diameter (193.0 x 50.3 mm) • Output connector: Integral 3-pin XLRM-type • Accessories furnished: AT8405a stand clamp for 5/8"-27 threaded stands, 5/8"-27 to 3/8"-16 threaded adapter, AT8114 windscreen, battery, and a soft protective pouch • Audio-Technica case style: S7.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAT8031
  • Part Number242-4202
  • UPC4961310098278
  • Product CategoryInstrument Microphones
  • Weight1 lbs.
View similar products to the Audio-Technica AT8031 Cardioid Condenser Handheld Microphone
in the Instrument Microphones product category.
