Audio-Technica AT4060 Cardioid Condenser Tube Microphone
Brand:|Model: AT4060|Part # 242-4184
Audio-Technica's AT4060 cardioid vacuum tube condenser brings the warmth of vintage tube sound to every shade of the SPL spectrum. Achieves the classic sound of valve design without compromising the specification standards required for the most demanding recording situations.
ORDER TODAY
Ships in 5-7 business days
List Price$1,815.00
You Save20%
$1,449.00
Part # 242-4184
  • Vintage tube sound with the versatile performance necessary for demanding studio applications
  • Wide dynamic range, low self-noise and high max SPL capability
  • Regulated and heavily filtered heater current prevents noise contamination of audio signal chain
  • Hand-selected tubes are individually tested and aged to maintain peak performance
  • Large coupling transformer provides superior low-frequency linearity
  • Custom shock mount provides superior isolation
Frequently Bought Together
Audio-Technica's AT4060 cardioid vacuum tube condenser brings the warmth of vintage tube sound to every shade of the SPL spectrum. With a dynamic range that far exceeds that of other tube microphones, it as easily captures the subtlest nuances of vocal and instrumental performance as it handles guitar cabinets and other extreme SPL environments. Featuring hand-selected, individually tested and aged tubes, the AT4060 achieves the coveted, classic sound of valve design without compromising the specification standards required for the most demanding recording situations. The 2-micron-thick, vapor-deposited gold diaphragms undergo a five-step aging process so that the optimum characteristics achieved remain constant over years of use. Dual-diaphragm capsule design maintains precise polar pattern definition across the full frequency range of the microphone. Precision-machined, nickel-plated brass, acoustic element baffle provides enhanced element stability and optimal sensitivity. Includes furnished accessories: AT8560 power supply, AT8447 shock mount for 5/8"-27 threaded stands, rack-mount adapters for power supply, and a protective mic carrying case.
Specifications: • Element: Externally polarized (DC bias) condenser • Polar patterns: Cardioid • Frequency response: 20-20,000 Hz • Open circuit sensitivity: -34 dB (19.9 mV) re 1V at 1 Pa • Impedance: 200 ohms • Maximum input sound level: 150 dB SPL, 1 kHz at 1% THD; 149 dB SPL, 1 kHz at 0.5% THD • Noise: 19 dB • Dynamic range (typical): 131 dB, 1 kHz at Max SPL • Signal-to-noise ratio: 75 dB, 1 kHz at 1 Pa • Power requirements: AT8560 power supply (120V/230V AC) • Dimensions: 8.27" (210.0 mm) long, 2.10" (53.4 mm) maximum body diameter • Power supply: 8.27" (210.0 mm) W x 8.86" (225.0 mm) D x 1.73" (44.0 mm) H • Output connectors: XLRM-type (on power supply) • Cables: 32.8 ft. (10 m) cable with 6 pin XLR-type connectors for use between microphone and power supply; AC power supply cable.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAT4060
  • Part Number242-4184
  • UPC042005308958
  • Product CategoryLarge Diaphragm Condenser Microphones
    (1 Reviews)
  • Weight11.35 lbs.
View similar products to the Audio-Technica AT4060 Cardioid Condenser Tube Microphone
in the Large Diaphragm Condenser Microphones product category.
