Audio-Technica AT4053b Hypercardioid Condenser Microphone
Brand:|Model: AT4053b|Part # 242-4180
Featuring direct-coupled balanced outputs for clean signals in high-output conditions, the AT4053b is totally free of the distortion associated with conventional transformer-coupled outputs.
ORDER TODAY
Ships in 5-7 business days
$599.00
Part # 242-4180
  • Specially engineered to meet the most critical acoustic requirements of professional recording
  • Hypercardioid polar pattern reduces pickup of sounds from the sides and rear
  • Direct-coupled, balanced output results in a clean signal even under high-output conditions
  • Transformerless circuitry virtually eliminates low-frequency distortion
  • Switchable 80 Hz hi-pass filter and 10 dB pad
  • Rugged turned-brass microphone housing for enduring dependability
  • State-of-the-art design & manufacturing techniques ensure compliance with A-T’s stringent standards
Frequently Bought Together
This versatile studio performer may be used with confidence in a wide variety of professional miking applications. Featuring direct-coupled balanced outputs for clean signals in high-output conditions, the microphone is totally free of the distortion associated with conventional transformer-coupled outputs. And its fast response to transients contributes to the open, transparent reproduction of even the most difficult-to-capture instruments. The microphone is fully RoHS-compliant – free from all substances specified in the EU directive on the reduction of hazardous substances (RoHS). The AT4053b consists of two modular subassemblies: an AT4900b-48 body and an AT4053b-EL hypercardioid head capsule (both available separately).
Specifications: • Element: Externally polarized (DC bias) capacitor • Polar pattern: Hypercardioid • Frequency response: 20-20,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: -34 dB (19.9 mV), re 1V at 1 Pa • Impedance: 50 ohms • Maximum input sound level: 145 dB SPL, 1 kHz at 1% THD; 155 dB SPL, with 10 dB pad (nominal) • Noise: 16 dB SPL • Dynamic range (typical): 129 dB, 1 kHz at Max SPL • S/N ratio: 78 dB, 1 kHz at 1 Pa • Phantom power requirements: 48V DC, 4.8 mA typical • Switch: Flat, roll-off; 10 dB pad (nominal) • Dimensions: 6.10" long, 0.83" maximum body diameter (155.0 x 21.0 mm) • Output connector: Integral 3-pin XLRM-type • Optional interchangeable elements: AT4049b-EL (omnidirectional); AT4051b-EL (cardioid) • Accessories furnished: AT8405a stand clamp for 5/8"-27 threaded stands; windscreen; protective carrying case • Audio-Technica Case Style: S1.
  • Element TypeCondenser
  • Polar PatternHypercardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAT4053b
  • Part Number242-4180
  • UPC042005156023
  • Product CategoryInstrument Microphones
    (3 Reviews)
  • Weight1 lbs.
View similar products to the Audio-Technica AT4053b Hypercardioid Condenser Microphone
in the Instrument Microphones product category.
