Audio-Technica AT4050ST Stereo Condenser Microphone
Brand:|Model: AT4050ST|Part # 242-4175
Offering the realism of a live sound field, the AT4050ST is a side-address condenser with cardioid and figure-of-eight elements configured in a Mid-Side arrangement.
ORDER TODAY
Ships in 5-7 business days
$1,299.00
Part # 242-4175
  • Innovative side-address Mid-Side stereo mic engineered for professional recording & broadcast
  • Independent cardioid and figure-of-eight condenser elements
  • Switch selection of Mid-Side mode and two internally matrixed stereo modes
  • Dual-diaphragm capsules maintain precise polar pattern across full frequency range of mic
  • Transformerless circuitry virtually eliminates low-frequency distortion
  • The 2-micron-thick, vapor-deposited gold diaphragms undergo a five-step aging process
  • Open acoustical environment of symmetrical housing assembly minimizes unwanted internal reflections
Offering the realism of a live sound field, the AT4050ST is a side-address condenser with cardioid and figure-of-eight elements configured in a Mid-Side arrangement. This innovative stereo condenser allows sound recordists the choice of selecting a left-right stereo output or choosing discrete Mid-Side signals for later manipulation, a remarkable flexibility. The microphone's dual-diaphragm capsules maintain precise polar pattern definition across the full frequency range. Its transformerless circuitry virtually eliminates low-frequency distortion.
Specifications: • Element: Externally-polarized (DC bias) condenser • Polar pattern: Cardioid and figure-of-eight • Frequency response: 20-18,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: Stereo 90°: -42 dB (7.9 mV) dB re 1V at 1 Pa; Stereo 127°: -41 dB (8.9 mV) dB re 1V at 1 Pa; Mid: -36 dB (15.8 mV) dB re 1V at 1 Pa; Side: -36 dB (15.8 mV) dB re 1V at 1 Pa • Impedance: 50 ohms • Maximum input sound level: Mid and side 149 dB SPL, 1 kHz at 1% THD; 159 dB SPL, with 10 dB pad (nominal) • Noise: Stereo 90°: 25 dB SPL; Stereo 127°: 16 dB SPL; Mid: 15 dB SPLSide: 17 dB SPL • Dynamic range (typical): Mid 134 dB, 1 kHz at Max SPL; Side 132 dB, 1 kHz at Max SPL • S/N ratio: Stereo 90°: 69 dB, 1 kHz at 1 Pa; Stereo 127°: 78 dB, 1 kHz at 1 Pa; Mid: 79 dB, 1 kHz at 1 Pa; Side: 77 dB, 1 kHz at 1 Pa • Phantom power requirements: 48V DC, 6.4 mA typical (both channels total) • Switches: 90°, 127°, M-S; Flat, roll-off; 10 dB pad (nominal) • Dimensions: 7.60" long, 2.10" maximum body diameter (193 x 53.4 mm) • Output connector: Integral 5-pin XLRM-type • Cable: 16.5" (5 m) long, 8-conductor, shielded, vinyl-jacketed stereo cable with 5-pin XLRF-type connector at microphone end and two 3-pin XLRM-type connectors at output end • Accessories furnished: AT8449 shock mount for 5/8" -27 threaded stands, microphone dust cover, and a protective carrying case • Audio-Technica case style: R1.
  • BrandAudio-Technica
  • ModelAT4050ST
  • Part Number242-4175
  • UPC4961310106676
  • Product CategoryLarge Diaphragm Condenser Microphones
    (1 Reviews)
  • Weight0.01 lbs.
View similar products to the Audio-Technica AT4050ST Stereo Condenser Microphone
in the Large Diaphragm Condenser Microphones product category.
