Audio-Technica AT-LP60 Fully Automatic Belt Driven Turntable
Brand:|Model: AT-LP60|Part # 240-5528
With its built-in switchable phono preamp, the AT-LP60 may be connected directly to your computer, home stereo and to other components that have no dedicated turntable input.
List Price$119.95
Regular Price$99.00
You Save10%
Sale Price
$89.00
Part # 240-5528
  • Fully automatic operation with two speeds: 33-1/3 and 45 RPM
  • Professional aluminum platter
  • Included cables connect to your stereo or powered speakers
  • Integral Dual Magnet™ phono cartridge with replaceable stylus
  • Switchable built-in pre-amplifier with line-level RCA output cables
Rediscover your classic 33-1/3 and 45 RPM records on this affordable, fully automatic belt-drive workhorse. With its built-in switchable phono preamp, the AT-LP60 may be connected directly to your computer, home stereo and to other components that have no dedicated turntable input. The turntable is supplied with an integral Audio-Technica Dual Magnet™ phono cartridge with replaceable stylus.
Specifications: • Type: Belt drive turntable, fully automatic • Motor: DC servo-controlled • Speeds: 33-1/3 RPM, 45 RPM • Turntable Platter: Aluminum • Wow and flutter: Less than 0.25% (WTD) @ 3 kHz (JIS) • S/N ratio: >50 dB (DIN-B) • Output level: Pre-amp "PHONO": 2.5 mV nominal at 1 kHz, 5 cm/sec • Pre-amp "LINE": 150 mV nominal at 1 kHz, 5 cm/sec • Phono pre-amp gain: 36 dB nominal, RIAA equalized • Power supply requirement: 120V AC, 60 Hz, 3W • Dimensions: 14.17" W x 3.84" H x 14.02" D (360.0 x 97.5 x 356.0 mm) • Weight: 6.6 lbs. (2.98 kg) • Accessories included: Dual RCA (female) to 3.5 mm mini-plug (male) stereo adapter cable, dual RCA (female) to 3.5 mm mini-plug (female) stereo adapter cable, and 45 RPM adapter.
  • Drive TypeBelt Drive
  • BrandAudio-Technica
  • ModelAT-LP60
  • Part Number240-5528
  • UPC042005159499
  • Product CategoryTurntables
    (3 Reviews)
  • Weight8.5 lbs.
View similar products to the Audio-Technica AT-LP60 Fully Automatic Belt Driven Turntable
in the Turntables product category.
