Audio-Technica AE4100 Cardioid Dynamic Handheld Microphone
Brand:|Model: AE4100|Part # 242-4014
Audio-Technica's high-performance AE4100 cardioid dynamic vocal microphone delivers aggressive sound that stays up-front in the mix. Optimized for the stage, the microphone features superior anti-shock engineering for minimum handling noise. The AE4100 has a frequency response of 90-18,000 Hz.
ORDER TODAY
Ships in 5-7 business days
$189.00
Part # 242-4014
  • Destined to be the next classic
  • Optimized for the stage with excellent isolation properties
  • The back-cavity assembly "floats" inside the handle shell
  • Superior anti-shock engineering for low handling noise
  • Multi-stage grille design offers excellent protection against plosives and sibilance
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • Outstanding pop protection
Audio-Technica's high-performance AE4100 cardioid dynamic vocal microphone delivers aggressive sound that stays up-front in the mix. Optimized for the stage, the microphone features superior anti-shock engineering for minimum handling noise. Its rugged construction is engineered to stand up to the rigors of touring. For ultimate protection against vocal plosives, the mic's hardened-steel outer grille is lined with fine steel mesh and a layer of open-cell foam. A foam disk positioned on top of the element assembly provides the final layer of "pop" protection.
Specifications: • Element: Dynamic • Polar pattern: Cardioid • Frequency response: 90-18,000 Hz • Open circuit sensitivity: -55 dB (1.7 mV) re 1V at 1 Pa • Impedance: 250 ohms • Dimensions: 6.97" (177.0 mm) long, 1.89" (48.0 mm) head diameter, 1.30" to 0.87" (33.0 to 22.0 mm) tapered body diameter • Output connector: Integral 3-pin XLRM-type • Accessories furnished: AT8470 Quiet-Flex™ stand clamp for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter; soft protective pouch.
  • Element TypeDynamic
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAE4100
  • Part Number242-4014
  • UPC042005125166
  • Product CategoryVocal Microphones
    (1 Reviews)
  • Weight1.3 lbs.
View similar products to the Audio-Technica AE4100 Cardioid Dynamic Handheld Microphone
in the Vocal Microphones product category.
