Audio-Technica AE3300 Cardioid Condenser Handheld Microphone
Brand:|Model: AE3300|Part # 242-4012
With pristine audio quality, ultra-low handling noise, and high-frequency clarity, Audio-Technica's AE3300 gives voice to the subtleties of vocal performance. The AE3300 has a frequency response of 30-18,000 Hz.
ORDER TODAY
Ships in 5-7 business days
$279.00
Part # 242-4012
  • Exceptional performance for exceptional performers
  • Same element as the classic AT4033 studio microphone
  • Well-tempered polar pattern with outstanding rejection qualities
  • Superior anti-shock engineering ensures low handling noise and quiet performance
  • High-quality double-sided PCB uses surface-mount components
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • Multi-stage grille design offers excellent protection against plosives and sibilance
With pristine audio quality, ultra-low handling noise, and high-frequency clarity, Audio-Technica's AE3300 gives voice to the subtleties of vocal performance. This cardioid condenser vocal microphone is proven in the world’s finest recording studios. The hardened-steel outer grille is lined with fine steel mesh and a layer of open-cell foam for ultimate protection against vocal plosives without compromising high-frequency clarity. Its superior anti-shock engineering ensures low handling noise and quiet performance. For exceptional performance. For exacting detail. For brilliant clarity: AE3300. It’s the new standard in live audio.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 30 Hz - 18,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: -42 dB (7.9 mV) re 1V at 1 Pa • Impedance: 150 ohms • Maximum input sound level: 147 dB SPL, 1 kHz at 1% THD; 157 dB SPL, with 10 dB pad (nominal) • Noise: 19 dB SPL • Dynamic range (typical): 128 dB, 1 kHz at Max SPL • S/N ratio: 75 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 3 mA typical • Switches: High-pass filter; 10 dB pad (nominal) • Dimensions: 7.05" (179.0 mm) long, 1.97" (50.0 mm) head diameter, 1.30" to 0.87" (33.0 mm to 22.0 mm) tapered body diameter • Output connector: Integral 3-pin XLRM-type • Access furnished: AT8470 Quiet-Flex™ stand clamp for 5/8"-27 threaded stands; 5/8"-27 to 3/8"-16 threaded adapter; soft protective pouch.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAE3300
  • Part Number242-4012
  • UPC042005125142
  • Product CategoryVocal Microphones
    (1 Reviews)
  • Weight1.4 lbs.
View similar products to the Audio-Technica AE3300 Cardioid Condenser Handheld Microphone
in the Vocal Microphones product category.
