Audio-Technica AE3000 Cardioid Condenser Instrument Mic
Brand:|Model: AE3000|Part # 242-4010
The Artist Elite AE3000 delivers supreme performance at extreme SPLs. This high-SPL large diaphragm cardioid condenser instrument mic excels in applications such as guitar cabinets, toms, snare, timpani, horns and overheads. The AE3000 has a frequency response 20-20,000 Hz.
ORDER TODAY
Ships in 5-7 business days
$279.00
Part # 242-4010
  • Excels in high-SPL applications
  • Large-diaphragm capsule combines w/ the open architecture of the headcase to provide accurate sound
  • Low-profile side-address design with tapered grille allows optimal positioning of element vis-à-vis
  • Cardioid polar pattern reduces pickup of sounds from the sides and rear
  • Robust design for enduring dependability on the road
  • Integral 80 Hz HPF switch and 10 dB pad
The Artist Elite AE3000 delivers supreme performance at extreme SPLs. This high-SPL large diaphragm cardioid condenser instrument mic excels in applications such as guitar cabinets, toms, snare, timpani, horns and overheads. Its large-diaphragm capsule combines with the open architecture of the headcase to provide an extremely accurate and open sound. Its low-profile side-address design with tapered grille allows for optimal positioning.
Specifications: • Element: Fixed-charge back plate, permanently polarized condenser • Polar pattern: Cardioid • Frequency response: 20-20,000 Hz • Low frequency roll-off: 80 Hz, 12 dB/octave • Open circuit sensitivity: -43 dB (7.0 mV) re 1V at 1 Pa • Impedance: 100 ohms • Maximum input sound level: 148 dB SPL, 1 kHz at 1% THD; 158 dB SPL, with 10 dB pad (nominal) • Noise: 11 dB SPL • Dynamic range (typical): 137 dB, 1 kHz at Max SPL • S/N ratio: 83 dB, 1 kHz at 1 Pa • Phantom power requirements: 11-52V DC, 3 mA typical • Switches: High-pass filter; 10 dB pad nominal • Dimensions: 4.55" (115.5 mm) long, 1.89" (48.0 mm) maximum diameter • Output connector: Integral 3-pin XLRM-type • Accessories furnished: AT8471 isolation clamp for 5/8"-27 threaded stands, 5/8"-27 to 3/8"-16 threaded adapter, and a soft protective pouch • Audio-Technica case style: R6.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAE3000
  • Part Number242-4010
  • UPC042005128006
  • Product CategoryInstrument Microphones
  • Weight1 lbs.
View similar products to the Audio-Technica AE3000 Cardioid Condenser Instrument Mic
in the Instrument Microphones product category.
