Audio-Technica AE2500 Dual Element Kick Drum Mic
Brand:|Model: AE2500|Part # 242-4008
The ultimate kick-drum mic, the Artist Elite AE2500 dual-element instrument microphone features cardioid condenser and dynamic capsules combined in one housing. The AE2500 has a frequency response 20-17,000 Hz.
ORDER TODAY
Ships in 5-7 business days
$549.00
Part # 242-4008
  • Revolutionary dual-element design represents a ground-breaking transducer achievement
  • Two elements (condenser and dynamic) are enclosed in a single housing
  • Elements are positioned in a perfect phase relationship
  • Robust design for enduring dependability on the road
  • Integral 80 Hz HPF switch and 10 dB pad on condenser element
  • Includes isolation clamp for shock protection, secure mounting and easy positioning
  • Includes a 16.5' (5 m) cable (5-pin XLRF to two standard 3-pin XLRM connectors)
The ultimate kick-drum mic, the Artist Elite AE2500 dual-element instrument microphone features cardioid condenser and dynamic capsules combined in one housing. The dynamic element delivers the aggressive attack of the beater; the condenser captures the round tonalities of the shell. Two layers of resistive mesh form multiple densities over the dynamic element's side-entry ports, exercising precise control over the time at which off-axis signals arrive at the diaphragm. The condenser diaphragm is optimally tensioned and aged for long-term consistency and stability.
Specifications: • Elements: Condenser, dynamic • Polar pattern: Cardioid • Frequency response: 20-17,000 Hz (condenser), 30-10,000 Hz (dynamic) • Low frequency roll-off: 80 Hz, 12 dB/octave (condenser) • Open circuit sensitivity: -51 dB (2.8 mV) re 1V at 1 Pa (condenser), -54 dB (1.9 mV) re 1V at 1 Pa (dynamic) • Impedance: 100 ohms (condenser), 600 ohms (dynamic) • Maximum input sound level: 148 dB SPL, 1 kHz at 1% THD (condenser), 158 dB SPL, with 10 dB pad (nominal) • Dynamic range (typical): 124 dB, 1 kHz at Max SPL (condenser) • S/N ratio: 70 dB, 1 kHz at 1 Pa (condenser) • Phantom power requirements: 11-52V DC, 3 mA typical (condenser) • Switches (condenser Only): High-pass filter; 10 dB pad nominal • Dimensions: 6.50" (165.0 mm) long, 2.17" (55.0 mm) maximum diameter • Output connector: Integral 5-pin XLRM-type • Cable: 16.5 ft. (5 m) dual shielded, 8-conductor cable, 5-pin XLRF-type connector at microphone, two 3-pin XLRM-type output connectors • Accessories furnished: AT8471 isolation clamp for 5/8"-27 threaded stands, 5/8"-27 to 3/8"-16 threaded adapter, and a soft protective pouch • Audio-Technica case style: R8.
  • Element TypeCondenser
  • Polar PatternCardioid
  • On/Off SwitchNo
  • BrandAudio-Technica
  • ModelAE2500
  • Part Number242-4008
  • UPC042005128983
  • Product CategoryInstrument Microphones
    (1 Reviews)
  • Weight2.4 lbs.
View similar products to the Audio-Technica AE2500 Dual Element Kick Drum Mic
in the Instrument Microphones product category.
